york audio IR
I have some IR from York audio  can anyone tell me what the 3 files of  minimum phase singles  -   mixes - natural  phase singles
are?
  • They are for when you are mix and matching IR’s from different packs. Sometimes the IR’s will be out of phase with each other. So the minimum phase IR’s help with that.
    I’m sure the enclosed PDF in the packs explains this though.
    I normally stick to the mixes with the York Audio stuff. Mix 1 is normally just fine and is usually a mix of a SM57 and Royer121.
  • OctavioOctavio Frets: 153
    There's a PDF that comes with the IR pack that explains it. It should be in the folder. I typically just use the mixes.
  • VoxmanVoxman Frets: 4784
    Ditto
