Getting a pickguard cut?
Hi all. I have a partscaster EGC type guitar, and I'd like to get a new pickguard. It will have to be a custom job.
Is it relatively easy for someone to do? I would probably look to send the pickguard to them. It's a case of them tracing it on a piece of paper and away they go? Or is it more complex than that? Any recommendations? Even good folk of the TFB parish in the UK or Europe?
  • SteveRobinsonSteveRobinson Frets: 7077
    The process is to trace it onto some MDF or plywood and cut a template. You use the template to rout the outline plus any chamfer.
    What's an EGC type guitar?
  • thermionicthermionic Frets: 9671
    Tiny Tone specialise in this kind of thing. I’ve sent a couple in and they made perfectly fitting replacements.
  • The process is to trace it onto some MDF or plywood and cut a template. You use the template to rout the outline plus any chamfer.
    Electrical Guitar Company. It's a body similar to the EGC, but with a telecaster neck. Thanks for the info, I will look into it.
  • Tiny Tone specialise in this kind of thing. I’ve sent a couple in and they made perfectly fitting replacements.
    Thanks!
  • +1 for tinytone
    fast turnaround too
