SOLD Bluguitar Fatcab 1x12 - £200
supessupes Frets: 185
edited March 2 in Amps £
Bluguitar Fatcab 1x12 for sale
Been used a few times but in really good condition. Comes with a protective cover that cost an additional £40.
These are over £500 new.
£200 collect/meet in north-east.
From Bluguitar-
The compact 1x12 FATCAB comes surprisingly close to mimicking the sound characteristics of old 4x12 cabs. With only one speaker, its optimum working range is reached much faster, making the sound very lively and smooth. The Thiele bass reflex system and the extreme rigidity of the cabinet produce a well defined and dynamic bass response with a massive low-end even at low volumes - just like you would normally expect from a large 4x12".
The cab's dimensions also serve up an extra portion of lower mids. Even at high volumes, the speaker remains balanced and does not tend to boom. The BluGuitar BG12-F speaker with an extra-fat magnet stays controlled at all times and delivers a harmonious midrange and soft highs, which are made even silkier by the filter effect of the front cover with the thick Basket Weave.
Specifications:
Type: 1x12 closed back
Power: 60 watts
Impedance: 8 Ohm
Speaker: 1x12 BG12-F
Housing: birch multiplex, extremely stiffened
Tolex: Black levant
Front grille: black Basket Weave
Weight: 14,5kg
Dimensions: 410 mm x 550 mm x 295 mm
Connections: 1x Mono In, 1x Parallel Out, 1x Serial Out (6.3mm jack)
https://hosting.photobucket.com/images/oo6/superleeb/IMG_0144.jpeg
  • rockmonsterrockmonster Frets: 839
    Postage an option?
  • supessupes Frets: 185
    edited March 1
    @rockmonster  I'd have to check the size/weight and look at couriers. It's not usual size of 1x12, it's bigger/wider
    Cool
    Can courier the cab for £20
