WITHDRAWN: 1973 Fender Stratocaster left-handed
RevolutionsRevolutions Frets: 259
edited May 7 in LH Guitars £
1973 Strat in great condition. All original, except case. I have the trem arm, too. Three areas of wear on the body, two on the front- the one above the scratchplate is a burn mark - presume someone trying to play & smoke? The 70s were a different time  B
It's light & the pickups are pretty punchy. Neck is small at the nut & a fairly slim neck all round. If you're looking for a baseball bat, this probably isn't for you.
I've never seen an original finish pre-75 CBS strat before. This has got staggered pole pieces & of course 3-way pickup switch.
 I'm in London, SW9.
Would love for you to come and try it out if possible, although happy to courier - need to work out cost.
£3,200
  • CarpeDiemCarpeDiem Frets: 296
    Nice guitar! It looks like a left-hander to me, unless the first photo has been reversed. If so, it may be worth noting this in the description. GLWS.
  • RevolutionsRevolutions Frets: 259
    Will do, thanks. Do the LH Guitars show in the normal for sale forum too?
    The listing will just appear in the ‘LH Guitars’ section as far as I’m aware. However, this is probably the best place for someone who is seeking a left hand guitar.
    This is now with a shop on Denmark St for commission sale.
    Confirmed 100% original electrics. Neck stamped “special order”
    cheers  :)
