Plectrums that don’t chirp
longshinslongshins Frets: 246
I was laying down some tracks today and the lead sections have lots of ‘chirp’ on the attack. I use a red jazz III and was wondering what a good non rip off version might be that will get rid of the noise. I know technique adjustments help but in this case it was a particularly silly shreddy thing and there was no way round it.
  • brooombrooom Frets: 1175
    The picks that lollar (that's right the pickup maker) sells are made from the same paper celulose material as the bottom of a vintage strat pickup. They are most excellent as a pick material,  no chirp.
  • danishbacondanishbacon Frets: 2698
    I’m happy with Blue Chip
  • KurtisKurtis Frets: 726
    Nylon?
  • JetfireJetfire Frets: 1696
    In my experience, I found thick picks chirp. I went from 2mm ultex sharp to 0.88mm and the chirping stopped.  If the edge isn't bevelled or shaped, you don't get that kind of noise I found.
  • fretmeisterfretmeister Frets: 24563
    Hard plastic against roundwound strings = chirp.
    Not sure it can be got rid of completely unless you want flatwounds.
  • StuartMac290StuartMac290 Frets: 1473
    Blue Chips don't chirp. Or wear out, for that matter.
  • crunchmancrunchman Frets: 11465
    Expensive if you lose them though.
  • ToneControlToneControl Frets: 11957
    I switched to 3mm stubby in the 80s or 90s, to slow me down and get more control
    I recently decided that on the metal patches, they make quite a bit of noise, so I have switched to using normal picks for that.
    So far just cheap ones that just about bend
  • DanielsguitarsDanielsguitars Frets: 3297
    I was trying thicker picks recently and stopped because I hated the chirp, I'm now back on ultex .73 and I'll stick with these, I'm now trying to improve my terrible picking
    www.danielsguitars.co.uk
    (formerly customkits)
  • digitalscreamdigitalscream Frets: 26720
    I use brass or wooden picks, for exactly this reason. Thin brass picks don't chirp, and they last a lot longer than even the hardest (ebony or lignum vitae) wooden ones.
    <space for hire>
  • digitalkettledigitalkettle Frets: 3296
    You lose 50p plectrums…you don’t lose £30 plectrums ;)
    2reaction image LOL 0reaction image Wow! 9reaction image Wisdom
  • TeleMasterTeleMaster Frets: 10269
    That's so weird, I was just trying to EQ out my chirps on something today, with little success.
    As it happens, that's a great side-effect of the brass picks I use - you can hear them when they hit the floor. Wife bought me five of them three years ago, and I've still got all five.
    <space for hire>
  • nero1701nero1701 Frets: 1462
    I generally don't lose them, I also find that after you've used them for a while and you loose the sharp angle on them, they become a bit quieter
    btw do any of you intentionally use the edge of the pick to select higher harmonics whilst doing an OD solo?
    I used to do that a lot
  • timmypixtimmypix Frets: 2408
    I find the black ones chirp less - can't remember which is which material but I have noticed the red ones sound different. So that could be a starting point for familiar feel and then go from there?
    Tim
  • goldtopgoldtop Frets: 6180
    I don't mind it sometimes, but it can get a bit OTT:
  • mgawmgaw Frets: 5291
    Blue chip for the win
  • nacnudnainacnudnai Frets: 247
    I've recently moved to thin picks (0.50 and 0.60mm small teardrop tortex) from about 12 years of almost exclusive use of Jazz IIIs. One thing I noticed almost immediately was the significant lack of chirp on the high strings. Low strings do the "cello" thing that Paul Gilbert talks about
  • StevepageStevepage Frets: 3061
    I’d recommend the Dunlop H3 picks. Same shape as the Jazz III but made of Tortex. Never had an issue with pick chirp with those
