Acoustic saddle nut?
dazzer22dazzer22 Frets: 44
I wanted  to upgrade my saddle nut to bone ,  But then I just realised  the saddle is in two parts , I have a Takamine gn20 and it has one long and one short  piece.  I am  sure if this is just one big saddle that  has been  cut into two or it this is an actual type of saddle.
  • ICBMICBM Frets: 72619
    It's an actual type of saddle, you can buy them in the correct sizes for a Takamine.
    Depending on which version of the G series it is, you may need an even more specific type that the pickup fits directly onto, rather than being a flat strip under the saddle. If so, you need one of these - https://www.ebay.co.uk/itm/172351092251 - take the existing saddle out and have a look.
    Not cheap, but there's a lot of work in making those.
  • dazzer22dazzer22 Frets: 44
    edited March 10
    I don't have a pickup on the guitar,  The saddle is  flat on the  bottom.  So it looks like a normal saddle but  cut .
    That makes it a bit easier and cheaper, but you still need the double saddle not cutting a single one - the two halves together are longer than one normal saddle, since they overlap slightly.
    If you're making one from a typical plain blank you would be able to get the two halves out of one piece though.
