Plectrums that don’t chirp
  • guitarjack66guitarjack66 Frets: 1885
    I'm sorry to have to break it to you but you've bought a bird!
  • maharg101maharg101 Frets: 705
    The type and settings of amp or pedal overdrive/distortion used can make a big difference too.
    This one goes to eleven
    Trading feedback here
    I found certain picks have a moulding line right around the pick which is a stupid thing and used to really annoy me.
    I filed off those mould lines, then switched to taylors abalone I think theyre thermex ultra. I like them but theyre kinda dark sounding.
  • Hawk Picks work for me.
  • OffsetOffset Frets: 11928
    I have to be honest - in 45+ years of playing, I wouldn't know 'chirp' if it jumped up and shook my hand :-)
  • paulmapp8306paulmapp8306 Frets: 847
    edited March 11
    Recently watched a vid on this - with testing.  Pretty much EVERY Pick chirpfs to an extend.  Blue Chip is actually in the "highest chirp" group (though the lowest IN that group).
    without going into off materials (felt plectrums were tested......) the best performer (lowest chirp) were the Dunlop nylon Picks (Not the Torlex, they are medium chiprers).   Nylon proved to be the best material for anti chirp - though its among the fastest wearing.
    the best "weight to chirp" were the Nylon 1mm picks.
    for those that dont know what chirp is - or to listen to the options:
  • stratman3142stratman3142 Frets: 2201
    I ended up with red Jazz III's as a compromise. I previously used black and ultex Jazz III's, which I found were chirpier.  There's a video on this below:
    It's not a competition.
    Oops looks like we posted the same thing within 2 minutes of each other.
  • LewyLewy Frets: 4238
    Remember when everyone was buying Zendrives because they wanted the chirp?
  • fretmeisterfretmeister Frets: 24498
    I absolutely love that some nutter made a video on this.
  • digitalkettledigitalkettle Frets: 3288
    It's fair to say that Troy is a details person ;)
  • Fingers657Fingers657 Frets: 657
  • guitarmanglerguitarmangler Frets: 593
    It drove me crazy. I swapped to planet waves nylpro blue picks about 3 years ago ( after 30 years of jazz 3’s). They rough up better and reduce the chirp. Angling the pick to parallel to the string helps, too.
  • KurtisKurtis Frets: 700
    edited March 11
    Trouble is, the picks that don't chirp (chirp) won't be cheap (cheap).
    Ooh aah...
  • JeremiahJeremiah Frets: 631
    The thing that bothers me is not specifically chirp, but general inconsistency of tone between the wound and unwound strings. I find the scratchy sound you can get on the wound strings particularly irritating.
    It's not so bad with high gain as the distortion tends to smooth everything out, but playing clean, particularly arpeggios across all 6 strings, I really hate it when it goes "scratch, scratch, scratch, twang, twang twang."
    Picks with a smooth/rounded-over edge tend to reduce scratchiness, but can lack note definition on the unwound strings, while picks with a sharper/thinner edge get the note definition but tend to exaggerate the scratch.
    I've found the best compromise are thin (.60 to .73) nylon picks. The Dunlop Gels are also OK, but have a "pingy" sound that doesn't work for everything.
    Technique makes a difference - playing with the pick more parallel to the strings reduces the scratchiness, but requires holding my wrist at an awkward angle.
