Hi all! Has anyone got one of these in the house at the moment? I've got a friend's one in for repair that was sounding crackly & weird at certain points on the gain knob's travel.
I've given it a good bit of contact cleaner. It then made some *really* weird tremolo sorts of noises (I assume while the contact cleaner worked through and evaporated. But now sounds ok I think.
My main question now is just whether the gain pot is always a bit less stiff to turn than the others? This was actually my pedal originally but I can't remember how the knobs felt. Not that it necessarily matters if all else is well.
Any other thoughts also welcomed, obviously!
There's still a slight crackle as you turn the knob but I have a feeling they might also all do that. I haven't compared with my Archer yet because honestly I don't remember where I put it!
Clip here... https://youtube.com/shorts/pPfVSFkCUpk?si=bL0m2BIAqQNRUFTd
@Danny1969 @ICBM @anyoneelse !!
I'm assuming inside it's a regular Klon circuit ? if so there's only 3 chips .. 2 x TLO72 and the charge pump chip which is generally a 7660, 1044 or similar chip that doubles the voltage and inverts one half ... this is a CMOS switched chip and when it goes bad (normally because it's been reverse biased by the wrong power supply) it will create havoc on the power supply
I normally just change all 3 chips as that cost less than £4 from CPC in sm form, a little more in thru hole and the decoupling caps near the charge pump chip as a precaution
I did think it felt like a voltage issue, so your description sounds very plausible given the charge pump etc. Should be an easy fix at least, assuming that's right.
Cheers for the guidance @Danny1969 !!
