SOLD 2 x EMG 81 Active Pickup Set with LP harness, switch and socket
KrisGeeKrisGee Frets: 1325
edited April 17 in Parts £
Kirk Hammett's preferred configuration.
Factory fitted to an Edwards LPC and recently replaced with a different set and wiring.
Full drop in kit with pots, switch, socket, screws (no springs), battery clip, mounting hardware, etc. The only bits that need soldering are switch wires and ground from your guitar.
The lettering on pickups has worn a bit, other than that in great condition, no other wear or scratches to covers.
£100 PPG delivered takes them. The lowest I've seen anywhere for a full set with everything included.
Thanks for looking!
