Avantone Active Mixcube speaker with an amp modeller?
Vintage65Vintage65 Frets: 341
edited April 15 in Digital & Modelling
Anybody tried one as a low volume option?
Specifications
SYSTEM TYPE: Active (Self-powered) shielded full-range stereo pair
FREQUENCY RESPONSE: 90Hz - 17,000Hz (useful musical range)
IMPENDANCE: Nominal 8 ohms
MAX SPL: 104db @ 1 meter = 1%THD (PINK NOISE)
AMPLIFIER TYPE: Class A/B
AMPLIFIER POWER: 60 watts RMS@ .005% THD (1KHz)
AMP FREQUENCY RESPONSE: 22Hz-50KHz +0dB/- 3dB (90Hz-50KHz +/-0dB)
NOISE: S/N -113 dB
SENSITIVITY: 0dBu (.775VRMS) input at maximum volume (+6dB) = 104dB SPL
DRIVER: Proprietary design 5.25" cast aluminum frame / paper cone / shielded
CABINET: sealed / 18mm MDF / Dacron acoustical stuffing
INPUTS: XLR & TRS (COMBO JACK) +4/Balanced and -10 unbalanced
WEIGHT: 7.13lbs (per monitor)
  • Winny_PoohWinny_Pooh Frets: 7802
    edited April 15
    I have a different mixcube set... too small sounding IMO, but avantones should have a bit more low end. A pair of regular ported studio monitors will be better.
  • Vintage65Vintage65 Frets: 341
    edited April 15
    I have some ported studio monitors, but they tend to get a bit loud. I was thinking of something I could place nearby to keep the volume down. 90Hz doesn't seem too far off a normal amp, or would I be missing out on some key frequencies?
    https://producerhive.com/wp-content/uploads/2022/10/electric-guitar-eq-cheat-sheet.png
    I'd buy a Roland CM30 instead. I have used mine as a mini PA for acoustic and vocals loads and it's very versatile.
  • MusicwolfMusicwolf Frets: 3682
    The Avetones are not a 'nice' sounding monitor, but they are very revealing.  The philosophy is one of - if a mix sounds good on a Mixcube it will sound good on anything.
    There's a review from Sound on Sound here.
    That would be the main purpose of getting one, but I was thinking of dual-usage.
    That looks like it, cheers!
