SOLD NUX Atlantic Delay / Reverb £60 posted
kennedydream1980kennedydream1980 Frets: 1158
edited April 24 in FX £
Very versatile reverb / delay pedal. 3 types of reverb and 3 types of delay. The delay footswitch is dual purpose as an on/off switch and also a tap tempo. Switches on the back allow you to select instrument or line level and series or parallel operation.
You can change the signal flow of the pedal by holding down the switches on power up, so delay into reverb just hold down the delay switch on power up, and reverb into delay hold down the reverb switch on power up. Also if you hold down both switches on power up it activates kill dry.
The pedal is in good condition and fully functional and is updated to the latest firmware. No box with this and Velcro on the back.
£60 posted.
