A brief review: Mosky Transparent Overdrive
  • OilCityPickupsOilCityPickups Frets: 10901
    TimmyO said:
    Is M the MXR version of the Timmy? I don't know if that is supposed to be a genuine 1-1 recreation or a slightly tweaked version
    MXR is offered as 'same' - although the volume pot taper is different/wrong
    The volume pot is a tad sensitive ... but for £35 I won't argue.
  • LionAquaLooperLionAquaLooper Frets: 1181
    No I don't believe it is because other pedals from this Mosky series also have the M mode. Unless by sheer coincidence those other pedals are also emulating some MXR model in those modes.
  • TimmyOTimmyO Frets: 7639
    Maybe they're just a 'Mosky' option
    Red ones are better.
  • soma1975soma1975 Frets: 6952
    I've ordered one of these.
    Barely use overdrive but sometimes you just need it to get a different amp in the right place at the right volume so will report back. Had the Timmy, the MXR Timmy, the Caline, the Light speed and the old Danelectro clone.
    Currently at rehearsals I'm using the rehearsal space solid state Marshall - so I'm using the TP Overdrive along with Fender tweed emulation on my Joyo American into the clean channel.
    It's arrived.
    Fuck knows about the intricacies of the different modes but stuck it in Jan Ray setting with just past unity vol and gain on low and it happily takes my edge of breakup Marshall SV20 into happy lead territory.
    Not sure how much it likes to be stacked with stuff placed before it, seemed to gets bit noisy with my treble booster or fuzz face on. Might need a tinker.
    Absolutely worth it.
    soma1975 said:
    It's arrived.
    I use it with a TS808 after it.
    Also My Big Muff Deluxe Russian really sits up and begs with the little Mosky just 'warming up' the signal a bit. I use that combo to play Train Kept Rolling (Jonnie Burnette version with Grady Martin's distorted tone) .
    I wonder if it will run on 18v
    I don't fancy it going pop .... I rather like the little beast so I may let someone else 'head that caber' :-)
