USB printer to Wireless ?
Emp_FabEmp_Fab Frets: 24540
I've got an older, very reliable Brother laser that I use occasionally.  It's only got a USB interface, no Wireless.  I want to connect it to my WiFi network so I can print to it from any device, including android phones.  I'm not coughing up £50 for a dedicated print server as I have Raspberry Pi's and several old laptops that will never get used again.
I'm thinking the easiest solution is perhaps to connect an old laptop to it, share it, and when I need to print, I turn on the laptop and the printer and it should be visible on the network.  My only concern there is the time it will take to boot the laptop...  I don't want to be waiting 10 minutes before I can print.
Any other ideas ?  It's a HL-L5000D - and there's no specific driver for it on the CUPS website for a Pi based print server.  Ideally I want a solution where I just turn the printer on and start printing to it immediately, the prints coming out once the printer has warmed up.
Offset "(Emp) - a little heavy on the hyperbole."
  • SporkySporky Frets: 28901
    Does your router not have a USB port?
  • Emp_FabEmp_Fab Frets: 24540
    Probably, but it's in the kitchen and I'm not moving it - it needs to be there for several reasons.  The kitchen isn't a good place for a laser printer.  The easiest solution is a dedicated laptop attached as a print server I suppose.  At least it'll behave properly and won't be a pita to set up.
  • PabloPablo Frets: 38
  • strumjoughlampsstrumjoughlamps Frets: 3317
    Use your Pi as a print server
  • SnagsSnags Frets: 5420
    A million years ago you could get dedicated network print server appliances that were small and cheap, and aimed at this for SoHo.
    <Hits up Google>
    I make no comment on the brands, many of them will probably be horrible, as it's not really an enterprise issue, so it'll be all the cheapo places.
  • notanonnotanon Frets: 617
    Share the printer via windows, or whichever Operating system.
    Get a really, really long USB cable and drag it around the house to wherever you are?
    Pablo said:
    That looks interesting.  I note it's only listed under the OS-X operating system, which I obviously won't be running on a Pi.  There is a driver for Raspbian though....  But I know Jack shit about setting up printers in Linux or sharing them on a network.  I envisage it being a world of pain....
  • guitartangoguitartango Frets: 1030
    Emp_Fab said:
    Not really, few command in the terminal and you should be ok
    sudo apt install cups
    sudo cp /etc/cups/cupsd.conf /etc/cups/cupsd.conf.org
    sudo chmod a-w /etc/cups/cupsd.conf
    nano /etc/cups/cupsd.conf
    Listen 192.168.0.xx:631      # Listen on the LAN interface, Port 631 (IPP)
    sudo systemctl restart cups.service
    sudo usermod -aG lpadmin pi  (I take pi is the user)
    http://localhost:631/admin
    Rem ===== Is this really hard==========
    Rem ===== Then Driver===================
    “Ken sent me.”
  • rlwrlw Frets: 4740
    How much does a printer cost these days.......
    edited May 7
    True but brother lasers are normally  quite good !  Unlike their PC's
    “Ken sent me.”
    More than the perfectly good, low page count Brother duplex laser I already have.
  • p90foolp90fool Frets: 31757
    I know you're joking, but after years of begging and cajoling wireless printers to actually do something I finally bought myself a USB-only Brother laser printer and it's an absolute joy.
    I just walk over to the printer (which you have to do anyway to retrieve what you've printed) plug in the laptop and it starts printing in seconds.
    Sometimes things which have always just sat there and quietly worked for decades, like old printers and electricity meters are just the way things ought to be.
    That's a very sensible approach.
    I got lucky; my printer connects to the house network on a cable, the router is a print server, every PC - plus the phones and tablets - can see it and print to it.
    Lady BMcH thinks it's unholy.
    Actually.....   I could reach the router through the floorboards with a long USB.  I've already got the holes made as my CAT5 to my upstairs Wireless AP is going through it.
    Maybe run CAT5e or better and use USB baluns then - that gives you more options in future. The cheap Lindy ones are OK for that sort of thing, but you might need CAT6.
    Have you actually tried the brlaser driver on Pi? It’s by far your best option IMO
  • roundthebendroundthebend Frets: 1145
    Would a wireless router configured in bridge mode help? I bought a mini one for my digital mixer but it's not up to that task, it might work for you. It's a TP Link WR802n I think, if it'll solve your problem it'd be a cheap option.
