soundcloud.com/thecolourbox-1
If you are driving the power section you could fit an effects loop, like a Metro Zero Loss loop, headfirst loop, Mojotone loop etc. Run reverb in the effects. It is still before the power amp but before after the little bit of gain in the pre-amp.
If you want reverb after all the power amp drive then investigate the Fryette Power Station and use the loop on that.
Personally I find when driving the snot out of an amp at volume that reverb is not that important and may even be undesirable.
Not my area of noise-making I’m afraid;
someone else will have to help here!
For smoother tones the Tubescreamer is what you'll want, and probably a Klon clone of some sort.
The yard is nothing but a fence, the sun just hurts my eyes...
If you are playing the amp at lower levels you will probably need a couple pedals stacked to get the dynamic range.
A tube screamer into a clean amp is not the JB sound IMO.
The Guv’nor MkI is fantastic for adding a ‘dirty channel’ to a JTM45, with the amp set only just on the point of breakup so the pedal dirt blends naturally with the amp. You can then put a Tube Screamer in front of the Guv’nor as well - that’s the Gary Moore Still Got The Blues setup if I remember correctly.
If I wanted to add reverb to that I would put it after the Guv’nor but still in front of the amp.
The old (pre reissue) ones are subject to internet cork sniffing depending on where they were made. All that does is inflate the price of the ones made in Bletchley and drop the price of the Korean ones. They're otherwise identical.
Don't confuse with the Guv'nor II which comes in a more compact case, and is really a preamp Marshall-in-a-box to be used into a clean amp. Still very good, but the Mk. I is a much better use case for classic rock and blues I would say, especially with an amp as tasty as that.
Have you thought about any kind of attenuator or reactive load at all?
It would in theory be possible to mod the MkII to bypass the Deep section entirely, or make it switchable, but I haven’t checked how difficult it might be - there are mods you can find on the net which claim to make the 2 sound like the 1, but they’re just voicing changes and won’t produce the same result.
Watch the parking meters
