Musical terms.
mike_lmike_l Frets: 5700
edited August 2013 in Theory
Please feel free to expand/correct this (incomplete) list of musical terms
Piano - quiet
Forte - loud
tempo - the speed of the music
BPM - Beats per minute
Key - the note/chord which the tune revolves around.
Chord - 3 notes played together
Diad/dyad - 2 notes played together (usually outlines a chord)
triad - 3 notes (usually from a chord)
Pentatonic scale - a 5 note scale either major or minor
diatonic scale - a 7 note scale, either major or minor
Major scale - uplifting, happy sounding scale
minor scale - downbeat, sad sounding scale
arpeggio - the notes from a chord played individually
  • I asked a pupil if 'f' means loud what do you think 'ff' means? His guess was brilliant: "effing loud?" :)
    Perfect interval: when the MD buys the round
  • flippancy aside:
    I reckon
    • a chord is any group of notes played together but often containing a triad
    • a triad is a 3-note chord where the notes have a R 3 5 relationship
  • treble : women ain't nothing but
    PSN id : snakey33stoo
  • digitalscreamdigitalscream Frets: 26772
    IanSavage said:
    Semitone - two guitarists playing in unison.
    Unison - two bassists trying to play in harmony :D
    <space for hire>
  • ClarkyClarky Frets: 3261
    Diad: a fella from Cymru
    Triad: a fella from Hong Kong
    Legato: pick once.. at the start of the gig..
    Power Chord: the wire from the amp to the mains. One end is apparently called the root and the other called the 5th. But I get too confused to be certain as to which end is called what..
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • Amplifiers - These are like lions. They have mains and when you twist their knobs they roar.
    Tremolo: an oscillating fluctuation in volume
    unless of course you have a Fender
    Tremolno: a gadget that prevents a Strat from doing something that is not tremolo... lmao
    this is not quite right
    the key is essentially a combination of the series of intervals along with a "tonic" note whichy is used to determine the pool of notes from which the scale and chords are derived
  • mike_lmike_l Frets: 5700
    @ Clarky, thanks for the correction.
  • Score (n.):
    1. Musical notation for all of the instruments required to play the piece of music, laid out so as for the instruments' parts to be read in parallel
    2. The value of the number of goals scored by each side in a football match.
    Score (v.):
    To avail oneself of wackybacky for the weekend
    simple time: is where the count is divided by 2, 4, 8 etc..
    as in 1/8th notes and 1/16th notes in 4/4 time
    compound time: is where the count is divided by multiples of 3 to give a swing [triplet] feel
    so 12/8 is essentially the compound equivelent of 4/4
    and likewise, 9/8 is the compound equiv of 3/4 etc
  • Compound time - fresh air for high security prisoners?
  • FWIW Eric Taylor's AB Guide to Music Theory contains good definitions of musical terms.  Vol I has most of the stuff anyone will need. Vol II has the more esoteric stuff. Everyone should have a copy.
  • vizviz Frets: 10731
    Or check the ABRSM syllabus.
  • frankusfrankus Frets: 4719
    I reckon
    I know I've a rep for disagreeing but...
    a voicing is a group of three or more notes that can be interpreted as one or more chords.
    (this is really important for 7b9 or diminished chords - which are repeated every overtone)
    a triad can also be inverted 3 5 R or 5 R 3 ...
  • agreed triads or anything else can be inverted. I didn't say the notes had to be stacked in exactly R 3 5 order
    Fair enough,
    I was aiming to remove a piece of ambiguity (I percieved) rather than contradict what you'd said - but I can't be the judge of the success of that. ;)
    I'd say the R 3 5 relationship is founded on triadic harmony (stacked thirds) and that meaning is lost (or at least obscured) with inversions.
    When someone says: what chord is this - 3X3456  ... I call that a voicing. What chord is it? out of context? dunno... G13, Fsus, Csus4... probably G13 but could be an Em11/G.
    Equally, a voicing can reoccur with different timbres but be the same voicing (but not chord as a guitarist would know them): 10 X 10 11 X X === X5X56X === XXoX11 - same voicing, different fingering.
    I don't think I'm telling you anything you don't know, simply clarifying the terms I use for concepts you're already familliar with... I found the differentiations useful to clarify my thinking of stuff is all :)
  • "forte" actually means 'strong'.
    I mention this because it makes the dynamic marking fff 'reinforced' rather than 'loud', 'loud', 'loud'!!!
    another good basis for understanding music theory comes from the translation from the original language which has fed our current labelling system for theory. For example:
    'Scale' is the Greek (/indo european) word for 'ladder'
    'chroma' is the word for 'colour' (remember chromatography from school science class?)
    so the "chromatic scale" is "our most colourful ladder".
    Makes sense when you consider that it contains every note!
    Teacher, musician, generally an enthusiastic and peaceful idealist. Run the Contemporary Guitar Performance Workshop education project and the Audio Design Workshop studio. Online guitar and piano/keyboard lessons available over Zoom/Skype.
