Hey everyone
EDIT- New info, read this before reading the entire thread so you don't waste your time
Thanks for all the replies again, everyone.
I was messing with my distortion pedals last night... and you know
what, I think my Joyo Hot Plexi might just get heavy enough for what I
want (at least with a boost in front). If so, that's awesome, because
apart from being a bit light on distortion, it's virtually perfect for
what I want (plus I already have it so it'll save me money). I need to
try it with lower output single coils to be sure (plus I've heard some
horror stories about Joyo reliability so it could die tomorrow) but
initial thoughts are that I might not need to buy any new pedal. Sorry about that. If it does die on me, though, I have plenty of info to decide on something else. Thanks again for everyone's help.
I think I've decided that what I really need (!) to finish off (!) my pedalboard is a Marshall-in-a-Box pedal which will do both lower gain and more modern hot-rodded high gain Marshall tones (and everything in-between I suppose). Nothing really wrong with my current pedals, but I'm having to use 2-3 pedals to get those tones, and if I could find one pedal which would do it, it'd save a bit of pedalboard space.
I don't need it to do pseudo-clean boost and/or lower gain overdrive tones (as in overdrive pedal-type tones- I suppose you could describe more vintage Marshall tones as overdrive too and I obviously do want those type of tones!) or the really heavy stuff (as I have my Hardwire metal distortion for that).
Deal-Breakers- Needs to do more vintage Marshall tones (think Free, AC/DC, that type of stuff) through Jailbreak-era Thin Lizzy and early Van Halen into more modern hot-rodded high gain (80's hard rock and metal, hair metal) Marshall tones. And ideally do them all well
- Not super-expensive. My budget isn't set in stone, but my current frontrunner is the MI Super Crunch Box, which is £99, so around that kind of money (or less). Another £20 or so isn't a problem if it gets me something much better, but I don't want to end up paying £300 either.
- Needs to work with a variety of (tube) amps, both set clean and crunchy.
- Small. The SCB is only about 2" wide (and should fit on my board) so nothing much bigger than that.
- Runs off a regular centre-negative 9V power supply at a low current (since I might have to daisy-chain it). If it runs off a different power supply it'd need to come with its own supply (or at least have one available for cheap).
- Needs to take an OD pedal as a boost well (probably Boss SD1 or my Daphon clone of it).
- It's not a deal-breaker, but it'd be nice if I didn't have to do tons of tweaking to dial in those different tones, as I tend to set and forget.
Any ideas? As I said, my frontrunner currently is the MI Super Crunch Box, but I haven't tried it so there may well be far better options.
Thanks for your help
https://www.youtube.com/watch?v=uc81IZnLlvk&list=UUZnf3mdsauHpQu7Txmrf8ww
No idea what they cost but they are a British company so postage shouldn't be too much.
I'll agree with ICBM the Jackhammer is a brilliant little pedal.
I'll throw the Hardwire CM-2 into the mix as well, very similar (on the classic setting) to the Mk1 Guvnor, which is (at least to me) a proper Marshall in a box....
The Guvnor 2 is good, but the low control needs to be carefully set or you'll end up with nothing but low-end.
Jackhammer: I'd come across that one before, and it was definitely on my list. My only concern was the fiddly knobs and that it might be awkward to get the totally different settings without a ton of tweaking. It's kind of a catch-22- more settings means more ways to tweak (which helps you to get vastly different tones) but also makes it more awkward to get there )
JHS/Bluesbreaker is a low gain overdrive I think? I have the mooer clone and it is, at least. No idea how tweaked the JHS version is, though.
Weehbo- Looks very good (I've heard of them ok and I think they have a good rep) but seems to be very expensive, and also a bit big.
Catalinbread: Again, this one was on my shortlist, but I was under the impression (probably wrongly) the newer one was lower gain? Also it has an internal switch, which I hate. )
AMT: I'd forgotten about them. I'll check the video.
Cornstar: Never heard of them, will check the video.
Hardwire CM2: I already have that ) I'm using it as an overdrive, to me it doesn't sound that Marshally? ) Probably better not to discount user error on my part, though.
Guvnor 2: Similar concerns to the Jackhammer.
EDIT: Ok listened to the videos:
Cornstar sounds pretty good, but I'm concerned it might not get heavy enough (nor that the tone control is wide-ranging enough).
AMT sounds pretty good, but it says it's meant to be connected to a clean channel? Maybe that's just in theory and maybe it works fine over a crunchy tone too, but I'd like to have the option. )
ZVex Distortron again I'm scared it doesn't get heavy enough (and is a weird shape, as I said).
Anyone tried the super crunchbox? I think monquixote had one at one point, but I might be misremembering...
the JTM's MXR sized
The zvex Distortron or box of rock just wins I think. Hit it with a boost for higher gain. I use a visual sound son of Hyde and it's the only Marshall in a box I'd trade it for. They come up used quite a lot the box of rock is awesome. Boost and distortion in one box that can go from jtm overdrive right up to jcm800 heavy crunch.
The son of Hyde is great, but definitely a much better higher gain pedal than low. Try one if you can, but I doubt it's the right pedal for you.
Unless you're happy using the hardwire cm-2 for od and using a son of hyde for high gain, in which case, you'd be a very happy bunny. Awesome sounding box.
Yeah those Zvexes sounded pretty good in the PGS vid I found. Just I'm concerned they're not gainy enough (could be wrong) and are the wrong shape to fit on my board unless I massively rearrange it (and even then).
@fretmeister: Thanks
@JohnPerry: Interesting, thanks. I thought I looked it up on the Weehbo website and it seemed to be big like the other ones. Which one did I look up then? )
@Fretwired: Thanks. Problem is I don't really have room for two pedals- the pedals I already have would do just fine if I did! I suspect a couple of the pedals I already have aren't a million miles off an original guvnor, either (since I suspect they're original-crunchbox-based, which itself was guvnor-based I think).
