SOLD: Tom Anderson 3 strat pickups
guitarmanguitarman Frets: 52
edited February 2015 in Misc £
Just found this in storage so getting rid of them as I am not using them.
Comes with original box an instructions.
SD2
SD2R
SD2+
Tom Anderson does not make these anymore. its from my 2001 Classic s. The middle is rw/rp.
Fully working and needs a new home!
  • axisusaxisus Frets: 28347
    Oohhhh! Always wanted a set of them. Nothing to stick them in at the moment though ....
  • you could alwyas buy them and keep them for when you do! ;)
    It's a possibility I guess, but the GAS fund may never grow again and I seem to have moved away from strats.
    Me again!  Do these have covers?
  • they are black
  • ToneControlToneControl Frets: 12009
    can't find on the TA site
    do you have any more details or a link
    are they noise cancelling?
  • guitarmanguitarman Frets: 52
    Here is what it says on the covers
    Here is what is is.
    SD2
    SD2R
    SD2+
    esults for Serial Number -
    If neck Back Shape field comes up blank it denotes the standard neck back shape for that particular model guitar, i.e. Even-Taper (T/A Standard), Happy Medium (Cobra & Atom Standard), Crowdster Standard, or Baritom Standard.
    Model - Classic
    Body Finish - Tobacco Burst
    Body Wood - Alder
    Neck Wood - Hard Rock Maple, Rosewood Fretboard
    Neck Finish - Satin Finish
    Nutwidth - 1 11/16 in
    Frets - Heavy
    Back Shape -
    Hardware - Chrome
    Bridge - Vintage Tremolo
    Pickguard - Mint
    Pickups - SD2 SD2R SD2+
    Switching - 5 Way, Mini Switch Splits, Pull Adds Bridge, Vintage Voicing
    Strings - .009-.042 Elixir strings
    Comments -
    BFTS
  • Details
    Tom Anderson's SD series are a hum canceling single-coil sized guitar pickup.
    These patented pickups produce a big, full, rich tone that still has an open, sparkling, clear, single coil sound and a pleasingly percussive attack.
    The SD's are available as an SD1for medium/normal output. These are the most requested.
    SD1-for lower/traditional output.
    SD2for slightly increased power and fullness.
    SD2+ slightly hotter still, great for bridge single coil application to balance output with SD1's.
    Reverse wound models are also available for hum canceling combinations when splitting: SD1R,SD1-RSD2R & SD2+R.
    Choose regular SD for hum canceling with split humbuckers and R for hum canceling with split regular SD's.
  • Bump for some fantastic Pickups at an amazing price!
