Yamaha HS7 monitors
I've managed to borrow a pair of HS7 monitors to try out for a few weeks..
surprisingly, they are blowing away my trusty KRK V6 mk1 monitors..
the seem to go lower, higher and have better clarity..
  • John_PJohn_P Frets: 2750
    I've got a pair of the little hs5's that pair up with my huge old tannoy's - no bass like the 7's probably have but I like the detail in the mids.  Nice monitors and the white centre is cool ;-)
  • ClarkyClarky Frets: 3261
    interestingly... my KRK V6 cabs are slightly larger than the HS7's [same depth / height but the V6 are a little wider]..
    but the HS7's have deeper and more focused low end...
    also, I think some of the low end clarity may be because the HS7 ports are to the rear.. whereas the KRK port is a slot at the front.. when I compared the m side by side it was only then that I noticed something I hadn't noticed before.. that was the turbulence coming from the KRK's port... I'd never noticed it before.. mental...
    I have a set of HS7s which I'm very pleased with.
    the other thing  forgot to mention is that the HS7 tweeters are quite strong.. especially for near-field [I'm less than 2m from each monitor..
    but they do have a switch on the back that allows you to knock off -2dB.. this worked perfectly for me..
    given how little these things cost [compared to a new pair of KRK VXT6 - which is I guess the latest equivalent to my V6], the are irritatingly good..
    now I've messed with them for a day.. I'm not surprised you're pleased with them at all
  • spark240spark240 Frets: 2090
    Yep...HS7 here too...
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • SnapSnap Frets: 6265
    Hs5, which for me are brilliant. Very clear and balanced, tbh I find them fine with bass and I love bass too. Also they are v good for listening to hi red commercial,audio purchases (I'm thinking the audiophile master of hesitation marks by nine inch nails in particular, sounds awesome)
  • guitarfishbayguitarfishbay Frets: 7963
    edited February 2015
    Clarky;506099" said:
    the other thing  forgot to mention is that the HS7 tweeters are quite strong.. especially for near-field [I'm less than 2m from each monitor..but they do have a switch on the back that allows you to knock off -2dB.. this worked perfectly for me..given how little these things cost [compared to a new pair of KRK VXT6 - which is I guess the latest equivalent to my V6], the are irritatingly good..
    This is why I sold my HS8s, even at -2 they were too bright. The 7s seem better balanced but I just never could get the 8s to work for me long term as I just ended up making dull sounding mixes. In the same price bracket I've had KRK G2 5 and 6 inches and they've got the opposite problem to some extent but I preferred that sound. Drew just got some Focal Alphas and he was really liking them.
    Monitor choice is really personal and also room specific, placement and treatment makes a big difference too. You've really got to try something for a while to see if it will work.
    I know what you mean.. I'll be trying these for a few weeks..
    the proof will be when I eventually get to doing a mix with them.. which I hope will be pretty soon..
