Hello all, now this could all be a massive pipe dream, but I'm hoping there's someone out there who wants a load of amps.
I'm not playing out anymore, so these could do with being shifted. I'm not 100% on getting rid as I still play them in the house a bit but they could do with being opened up on a regular basis as I've found they're all decent and have never failed on me.
Ideally I'd be looking for a trade where someone gives me a guitar or amp and takes one or all of these away, as I don't have the time or spend endlessly touting these for sale all over the shop.
I'm after collection/delivery within a reasonable distance of York, Durham or Cumbria, or will meet halfway depending on distance. :-)
So here goes...
Peavey 6505 212 USA 60w all valve Combo
All-tube 60 Watts RMS
Five 12AX7 preamp tubes.
Two 6L6GC power amp tubes.
Footswitchable lead/rhythm channel select
Effects loop
Footswitch is now included!
It's in decent condition with no tears in the tolex, a small tiny corner of the top plastic vent has cracked off but you'd be hard pressed to find it without being told about it. £400
http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsdotxm330.jpg http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsq034npvr.jpg http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsolkyyiat.jpg
Budda Superdrive 80 Series II 2x12 Combo
Description From the Budda website:
4 x 6L6GC
Custom Wound Transformer with 4/8/16 ohm switch
2 x 12" Custom designed Budda Phat 12 loudspeakers.
Exclusive Dual Class, Hot Bias preamp
3 x 12 AX7 Preamp Tubes
Rhythm and Drive Level controls
Brite control
3 band EQ
Pull Mid knob for "Modern" mid scoop
Effects Loop
Slave output with level control in parallel with power section
Point to Point hand wired power section
Weight Unpacked: 66.03 lb(29.95 kg)
Width Packed: 27"(68.58 cm)
Height Packed: 30"(76.2 cm)
Depth Packed: 15"(38.1 cm)
I've also had this serviced and modded by Dave at Rosewell Amps, Doncaster, no issues with it, and it now has the drive channel volume balance mod, using a pot so the lead boost is variable. Footswitch and cable included.
Sale £1000
http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsuswtmep5.jpg http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsx5jzd2aj.jpg http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsimxrunaw.jpg Marshall JVM210H 100w valve amp head - TRADED!
5 x 12ax7
4 x EL34
Footswitch included, good condition, a couple of knicks in the tolex. Sale £550 NOW TRADED
http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zps42eurqp1.jpg
http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsbvo7y6le.jpg
Sale £300
Egnater Armageddon 4x12 cab
With castors. Awesome thing, fitted with an led strip for 'awesome' stage lighting or home mood lighting! Well it seemed like a good idea at the time, less have a remote control so you can set the colour, brightness, strobe, flash, fade etc etc.
Specs from egnater are:
4x12” Extension Cabinet (Slant)
2 x Egnater Celestion® Elite 100 Loaded
2 x Celestion® G12T75 Loaded
350 Watts RMS
Automatic Impedance Sensing Terminal Plate
4Ω& 16 Ω Mono
8Ω Stereo
MIC Eliminator (Speaker Emulated)
Balanced XLR Output
ON / OFF Axis Select
Level Select
Ground Lift Switch
Rugged Birch Plywood Construction
250lb Load Rated Casters with Quick-Change Plates
Dimensions: 14”(Depth) x 29.75”(Width) x 29.75”(Height)
Weight: 88 lbs
Great condition, versatile with the direct out as well as for running two heads at the same time.
Sale £350
http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpslhg83bmc.jpg http://i1308.photobucket.com/albums/s611/andy1839/Mobile Uploads/image_zpsyuljyycz.jpg
Ideally as stated I'd love trades, guitars, other amps, don't mind, individually or as a job lot for something sweeeeet ;-)
Helpful critique is, as always, welcomed.
