P90s pot values for Tone. Opinions please
stonevibestonevibe Frets: 7181
edited October 2013 in Making & Modding
I have a rather nice Edwards LP Custom with Seymour Duncan P90s.
It has had some Orange Drop caps added by previous owner and I notice that the 'Tone' pots are 250k. I was thinking that 500k would give me some more 'bite' perhaps and maybe a bit more taper to play with.
So thought I would ask your opinions on whether or not they would benefit from me swapping out the tone pots.
EDIT
Either way the 500k are going in as I just broke one of the 250k pots when I pulled the knob off. Bloody post pulled right out of the casing!
  • ICBMICBM Frets: 72774
    Yes, 500Ks (with .022uF tone caps) are the standard values for P90s. It's nothing to do with being a 'single coil', it's the inductance of the pickup that matters, and a P90 is much more like a humbucker than a Fender-type single coil.
  • stonevibestonevibe Frets: 7181
    I did wonder why they had used 250K pots? I always thought they were for Fender single coils.
    Cheers fella!
    As always you're a wealth of good knowledge.
    Even if you do prefer Jags over Jazzmasters...
    Yup. That is a more what I wanted out of a tone pot.
    Old
    New
    What value are the volume pots? They should be 500s as well.
    They have no markings on the tops and I can't see the sides of them. I presumed they would be 500K as I know a lot of manufacturers use 500K and 250K with P90s for some reason.
    Either way I'll ditch them soon. I just had the two 500k pots left in my parts draw or I would have done the lot.
