Rivera Sedona 55 Combo Amp FOR SALE
Give me a call if you’re seriously interested.
This amp received a FIVE STAR RATING from guitarist magazine. Nick Guppy said this arguabley 'The Best Amp in The World'
I’ve purchased this form new and its a fabulous amp, in full working order.
Why am I selling it, well it’s to heavy for me now.
So give me a call 07860 555108
Thanks
This is on the web from the Guitar Store in Southampton 02380 339668
Rivera Sedona Acoustic & Electric Valve Guitar Amp 1x12 Combo
This is usually a Custom Order with a 4 weeks delivery - call for more information.
Sedona, the world's first all-tube Electric and Acoustic amp designed in collaboration with Nashville fingerpicking legend, Doyle Dykes. Accolades have been given to Sedona from all over the world. Sedona features two independent and different preamplifier channels. Channel 1 is designed to produce optimum electric tones, clean or distorted. Channel 2 is tailored for electric or acoustic instruments. Sedona's specially designed Tweeter can be switched on or off to reproduce an acoustic instrument's sparkling harmonics on demand. In addition, the Tweeter's operation is linked to Channel 2 and is automatically disengaged when Channel 1 is selected. An easy to use anti-feedback equalizer tunes out unwanted notes that would otherwise drone or squeal with sensitive acoustic Instruments. Switched from the front panel, the anti-feedback filter is also linked to Channel 2, and is automatically disengaged when using Channel 1. Reverb has never sounded sweeter, thanks to a long-pan, 6-spring Accutronics reverb. Another Rivera exclusive feature, the Sedona's built-in rear-panel tube direct box output, includes a level control and a pull switch for ground lift. It sends only the Instrument's signal through an all-tube low-impedance, balanced-line XLR output invaluable on-stage or in the studio. An active effects loop with level controls allows for matching any outboard signal processor for optimum tone and minimum noise. An internal acoustically tuned high-fidelity speaker system consisting of a high-efficiency 12" JBL speaker reproduces full frequencies and gives great guitar tone. A single high-power Dome Tweeter adds sibilance and definition to the high-end strings, especially on nylon or gut string instruments. Separate tweeter and full-range speaker output jacks coupled to an impedance selector allow connection to a Sedona Extension Enclosure to cover larger venues. Never before has an amp received so many rave reviews from guitar magazines. Guitar World as well as Guitar Player have used Sedona as their benchmark for testing other amps as well as many acoustic guitars. Guitar Shop Magazine said "This is undoubtedly the best acoustic/electric amp ever made.." Musician Magazine awarded Sedona "Amp of the Year." Specifications * 55 Watts, 1-12" JBL * (5) 12AX7 Preamp Tubes allowing 2 full discrete channels of warm tone * (2) EL-34 Power Tubes * Massive transformers and exposed surface mounting for long life and cool operation. * Heavy-Duty 16 Gauge zinc plated steel chassis with welded end make a rugged road worthy amp * Costly regulated DC filament power supply for the Preamp Tubes allow silent and hum free operation. * Rugged metal phone jacks throughout for years of noise free connections * Chassis mounted Mica-filled octal tube socket with phosphor bronze-copper plated and hot tin dipped pins for perfect electrical contact and long life * Detachable AC power cable for easy transportation and replacement Also available loaded with a Celestion G12T 75 speaker, price Â2306 We offer generous part exchanges against Rivera amps, contact us for more details!
  • WazmeisterWazmeister Frets: 9629
    Price ?
  • rlwrlw Frets: 4740
    Priceless by the sound of it.
  • Price ?
    £995.00
    £995.00
  • Sorry I forgot the price its £995.00
    Thanks
    I have some pictures but I don’t know how to import them into FretBoard. So if you want to see pictures of my amp just let me know.
    07860 555108
  • masslessmassless Frets: 24
    You don't post images directly to the forum, instead upload images here: http://postimage.org
    then copy the 'direct link' it gives you
    Go to 'Leave a Comment' on the forum, click the 'insert image' button above where your write your text and paste the link.
  • themanhimselfthemanhimself Frets: 0
    edited August 2015
  • Hi
    massless
    I tried but for me it didnt work
  • Rivera Sedona 55 Combo Amp FOR SALE £995.00
    I would consider P/X for lighter top quality combo such as Two-Rock Combo etc   I have some pictures and I have tried to import them into the Fret Board with no success. So if you want to see pictures of my amp just let me know. Or give me a call if you’re seriously interested 07860 555108
  • I have been asked so many times if I will consider sending the amp via a courier. So reluctantly I will agree to the following:-
    I will only consider sending the amp by courier, on the understanding that FULL RESPONSIBILITY will be that of the purchaser.  I would take photographs of the amplifier during packing right up to dispatch.
