a Q to all you bassy type peeples..
what sort of string height [over the 12th fret I guess] is considered to be a good / fast setup for a bass...
being a shredder, I measure my action by the number of atoms that'll fit between the string and 12th fret.. which in my case is about 11..
but on a bass, it look like everything is measured in meters..
so... how many meters [or yards in old money] from string to fret should I be looking for???
thanks matey... I'll check it out....
it's action is quite high... last night I shimmed its neck.. which improved things a lot.. but it still seems a bit high to me.. when I drop the action low, it's unplayable above the 12th fret cos it gets really buzzy and some strings choke.. I'm not expecting that to be normal so I'm guessing that it has a couple of high frets that need stoning..
