So, the other night a bulldog took a couple of bites at my beloved acoustic guitar... It now has a fairly big hole in the side and a small hole with accompanying cracks in the top...
Ideally I would take the guitar to a professional repair man but being totally skint this isn't really an option just now. Has anyone taken on a repair like this and could give me some information about how to go about it? After a bit of research online I was thinking about using magnets and glue to get a bit of veneer stuck behind the big hole and then trying to fill it from the front. Not too sure about the crack on the top... Was thinking maybe a sliver of wood to fill the hole and try to get some expanding glue into the cracks? Any advice would be greatly appreciated!
Cheers
You really need to tidy up the hole and cut a new bit to fit, which involves a bit of wood bending or cutting it from a donor guitar.
Could always just tidy the hole and make it a soundport for the dogs benefit.
Stabilise the cracks in the top by pumping in some glue, hide is best but superglue will work. Once stabilised you might be able to minimize the dents with steam. Splice in new bits where wood is missing, may also need some cleats inside as extra support
Stay away from expanding glue
Instagram
Sometimes the proper fix isn't viable. So a guerrilla bodge is preferable to scrapping the guitar. One of my mates filled a similar side hole with a fibre glass repair kit.... Looks terrible and makes me cringe, but it has been going strong for the best part of a decade. Still couldn't bring myself to recommend that method though
Instagram
Get yourself down to your nearest autoparts store and buy a tin of Plastic Padding and a packet of the aluminium mesh for filing holes.
Make the holes bigger if necessary, then cut a piece of mesh slightly bigger than the hole(s). Put some filler around the edges of the mesh, insert it into the hole with a pair of needle nose pliers and pull it up to stick it to the underside of the hole; hold it until it sets (doesn't take long). Then mix up some more filler and spread it over the mesh, just over flush with the upper surface. Once it hardens, rub down level with the surface, then spray with a suitably matching can of lacquer...
Yes it's a bodge, but it will only cost you about £25 plus your time; which is better than paying someone like me more than the guitar is worth to do it for you!
Sorry but no - that's a bad idea. Plus if you ever want it repaired properly, removing the bodge will be near impossible.
...it's a thin repair which can be invisible with a little care; no different to gluing bracing on the inside and a bridge on the top, or fitting electrics to a semi...
...but what else would you expect from someone who has the audacity to make/sell solderless control plates for those who don't mind admitting they can't solder!
This is the 21st Century; it's not all Lyres and Lutes now you know (unless you're Richie Blackmore of course!)...
Instagram
To use that on a guitar? Really? Splicing wood back in is a lot better solution, although I understand the comments on cost. If its that badly damaged, stabilise the hole and leave it as a hole - it's part of the guitar's "story".
I'll agree to disagree with you guys.
...I've probably been through gallons of 'Type Elastic' over the years!
These days I pay a body shop to cover up the 'Asda-Rash' our nice shiny new models always seem to attract, and each time it costs me more than those old bangers ever did :-S
The 'bodge' I advocated above is the ideal alternative to a trip to the local dump: and I've yet to see one of my 'bodges' fail to keep a customer happy...
...they're simply offensive to those who would rather see it done 'properly' but if they're not the one paying for it, and saving a significant wedge in the process, what's the problem?
We're not exactly talking about a Taylor or a Martin here now, are we...
