NGD - Vanquish Wudtone 0001
  • andypwudtoneandypwudtone Frets: 287
    edited November 2015
    prh777 said:
    Amazing looking guitars. Very hard to be different and classy but this does achieve it. Can you give an indication of price range for this type of build?
    Hi @prh77,  The vanquish range start from around £1995. A guitar with a top carve and Master grade maple cap is going to be in the £3500 area, something with a 4/5 A flamed maple cap £3300 and an all mahogany carve £2900.
    The process involves a total customisation of one of several basic platforms, in this case a Vanquish Mystique, where you get invited / consulted to choose pretty much everything from the start, ( which involves looking at a selection of top wood options), to the neck shaping, fret wire,  finish, pickups etc and even the knobs.
    kind regards
  • blueskunkblueskunk Frets: 2892
    Gets nicer every time I look.
    a quickly done v short clip of the guitar being played, little rock style rhythm, over which is a bit of clean ( first neck, the neck/middle pickup) , then a slight crunch, ( fave tone so far)  and finally a tad of balls out saturated. no doubt Vanquish will be doing some more pro stuff in due course and we will try to do a bit of a background to the development type vid when time allows. Hopefully you can get some idea of the quality of the guitar's lovely humbucker tones even if you can't get the feel for the playability, dynamics.
    chrs
