"One new development is in presets. There are 128 presets now, up from 4. 8 of them are accessed via 2 banks of 4 on the main control surface. 120 of them are accessed via sending MIDI PC messages."
Post #155
http://www.thegearpage.net/board/index.php?threads/source-audio-nemesis-delay.1539703/page-8
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
I'm im gigging and want to switch between presets it automatically activates as soon as I go up a preset. This is annoying.
If you go to Edit -> System -> Bank Mode you can set the footswitches so that when you scroll through banks it displays "BANK XX" on the screen but doesn't actually go in to a new preset until you hit the A or B footswitches. That's not quite what you want, but it's closer.
Alternatively, on my M5 if you save a preset with the effect engaged it's always engaged when you select that preset. If you save it with the pedal in bypass, it's always in bypass when you come back. I don't know for sure if the DD-500 works like that, but it might be worth a try.
