So which is the best Boss overdrive?
timmysofttimmysoft Frets: 1962
Has the forum decided on a champion?
SD-1
SD-1w
OD-3
BD-2
I'm putting together an all Boss board, so I'd love to hear opinions. Primarily being used as a boost for an already driven, modern voiced amp. I'm not looking for vintage or retro tones!
  • monquixotemonquixote Frets: 17702
    I love the od3 but for what you want an sd1 is the best bet
  • fretmeisterfretmeister Frets: 24687
    OD1x sounds nice to me
  • John_PJohn_P Frets: 2750
    OD1  but an SD1 is cheap and would sound great.
  • mike_lmike_l Frets: 5700
    SD-1's sound great with all (ok most) amp's and guitars.
    For heavier stuff, the DS-1 into a dirty Marshall is great. Better still is a modded DS-1 into a dirty Marshall.
  • stonevibestonevibe Frets: 7180
    SD-1 for me.
     But then it was my first ever pedal as a kid.
     So I learnt 'how to sound like a real guitar' using that and a JCM800 100 watt head, it pretty much was my only pedal for about two years till I bought a wah.
  • Lez325Lez325 Frets: 85
    edited January 2016
    SD 1 for me too- I push mine through a Marshall 15w Dual Lead amp with 2 x 1 x 12" cabs, does what it says on the tin, an awesome pedal for a mere outlay of around £39
    Les :)
  • SporkySporky Frets: 28836
    FDR-1 or BD-2, I'd say.
  • xSkarloeyxSkarloey Frets: 2962
    As a boost? SD1 all the way.
    I use it as a standalone too, natch.
  • DefaultMDefaultM Frets: 7385
    Why are you doing an all Boss board?
    I used to have the OD20 with all the different models in. Is that any good for you?
  • d8md8m Frets: 2434
    SD-1 for boost.
    OD-3 for standalone gain.
    The reason behind the boss board, is a bit of ocd, a bit of budget and a genuine love of what they make! I'm thinking the board will be sd1w, dm2w, tu3 and tr2.
  • JD50JD50 Frets: 661
    I didn't get on with the sd1 myself, I found it too rawk, I like the od3 the best.
    I'd add the od2 turbo overdrive to the list as well.   If I didn't already have an od1 and ds1 on my vintage boss board I'd grab another od2, one of my favourite boss pedals and they go very cheap.
    Agreed on the OD-2. It's almost become my core tone and it's the only pedal for which I bought a spare even though they're built like tanks.
    Oh, and between 20 to 30 quid on ebay.
  • normula1normula1 Frets: 640
    Had my OD2 for the best part of 30 years now. Still use it all the time, mostly on the non-turbo mode.
  • JezWyndJezWynd Frets: 6121
    My fave Boss drive pedal is the SD-2. Two modes, with separate drive and tone controls for each.
  • d8m;937818" said:
    SD-1 for boost.
    This!
    Don't discount the BD-2
    Ramp up the gain and it's a pretty Rock pedal
  • JadedJaded Frets: 127
    +1 for both the OD-2 and SD-2 from me. Both pretty different sounding for boss, I've found nothing that sounds like the SD-2's crunch mode and I quite regret selling mine, I found the lead mode to be a bit too scooped to be of much use for me.
    The OD-2 in non-turbo mode could definitely work well as a boost (though the OD-2r would be better) without quite as much of a low cut as you get with the SD-1... at least to my ears anyway. Turbo mode works great as a stand alone drive too if you ever needed that as an option.
