I recently got a Vibramate and Bigsby for my Tele. I also went for some Graphtech compensated saddles which arrived today so I've fitted everything. I've still not screwed down the bridge as I need to drill new holes (it's a 4-hole and the original was a 3-hole).
It looks like this:
I've done a (very) rough set up in that I've adjusted saddle height and rough intonation and overall I'm pleased - it sounds great (I've got Graphtech saddles on my main strat and I like the sound they give).
However, it seems to me that the saddles are too wide for the bridge. Both pairs of outside strings are on the inner limit of the saddle. Did I buy the wrong ones, or would it be acceptable to sand/file the inner end of the outer two saddles and both ends of the middle saddle to make the strings sit more centrally?
R.
If all the intonation screws are parallel then filling won't make any difference.
Eqd Speaker Cranker clone
R.
Can you see this?
https://goo.gl/photos/6dosyAVMDAtbertc8
R.
