Wanted: Strat neck with ebony board, 45-48mm wide at nut
goldtopgoldtop Frets: 6195
This is a bit of a long shot. I want a strat neck, ebony on maple. But I want it extra wide at the nut: somewhere between 45mm and 47.6 (the latter being the equivalent of Fender's 1 7/8ths).
Anyone got something suitable?
  • This is 7 string territory isn't it?
  • goldtopgoldtop Frets: 6195
    Not specifically, but you may be right. The 45mm is the dimension of an ESP guitar I have and I want to replicate that on a new Strat-alike.
    Seems Fender went as wide as 1 7/8ths at some point, and it's an option at Warmoth. Not sure if it's intended for 7-strings, though.
  • Good to know. Good luck with your search ;-)
  • SargeSarge Frets: 2429
    This could be a job for M.D. Phillips!
    Bumping this very old thread, because I've got some time now to actually get busy and make the guitar.
    All pointers welcome.
  • lamf68lamf68 Frets: 851
    Is he still master building?
    Who is he? UK-based? The obvious choice is one of those 1 7/8in necks from Warmoth, but I'd like to support a UK builder if I can.
  • Guitar Build and Haynes make necks with 1 3/4" wide nuts, which will be 44.45mm wide not 45mm wide, if it makes a difference.
    If it must be oversized at the neck then ignore, but otherwise I have at least 2 more conventional Warmoth ebony board necks available.. other necks going up soon too, but all conventional sized Warmoths/USA Custom Guitars...
    “He who joyfully marches to music in rank and file has already earned my contempt. He has been given a large brain by mistake, since for him the spinal cord would fully suffice.” Einstein
    Feedback link -  http://www.thefretboard.co.uk/discussion/133389/marshall#latest
    Hi there,
    I can build that neck for you for a fair price with top quality and extra inlay, logo and stuff. We can talk about wide dimensions but first of all it needs to be adjusted to a propper bridge. I know that Brian May's Red Special have oddly large nut because they've been using a classical guitar neck as an example. BUT the bridge is custom as well.
    I'm new here on the board, just joined today but I'm in "it" for quite a long time. Please have a look on my site to see some of my work: www.solomonguitars.co.uk and drop me a message if interested.
    I definitely want the nut width stated. Playing that Lynch ESP was a revelation, so I'm following the important bits of the tone recipe, and just going for super-simple aesthetics.
    @solomonguitars - thanks, I will check out your site. I wasn't too fussed about bridge saddle-saddle spacing. I suppose there must be an ideal geometry but I was imagining that it's simpler and more effective to choose a bridge that matches the pole positions of a conventional pickup.
