I thought they glossed over the setup as the intonation and action would have been shot.
Take it to bits and see if you can put it back again.
You may be right. Practice makes perfect, which is something that could never be said about my bass playing .
Funnily enough that didn't happen on the lawnmower one
I'm pretty sure you don't need one to assemble a Strat, unless you're starting from a tree.
Haven't seen the Strat one yet, will do on catchup.
The Suffolk Colt one made me chuckle a bit though, "the first thing we fit to the engine is the valves" erm, no you don't. Fit all the internals to the engine then fit the valves, otherwise you can't set the tappets which entails grinding a tad off the bottom of the valve stems. Or if too tight cutting seats and or lapping in.
Then again it was about reassembling, and not servicing and replacing with new parts, so I guess putting components back in the exact place they were originally located should work well enough.
What was the amp? It looked very nice.
http://3.bp.blogspot.com/-_VU02GALa_s/Tu0yDIOq5nI/AAAAAAAAIFA/k5JhAVbsHgg/s1600/Out+Of+Town+-+EP+14.avi_snapshot_23.19_%5B2011.12.18_00.18.31%5D.jpg
