Behold my massive board of pedals
1132133135137138394
  • djspecialistdjspecialist Frets: 908
    How are you finding the Nemesis?
    It's by far the fanciest delay pedal I have owned (in particular I haven't tried, let alone owned a TimeLine or DD-500), so I'm maybe not the best judge ... but I really like it.
    Good points:
    • Sounds out of the box are great - very little fiddling time required to get started.
    • Able to produce both clear and present delays, and darker / degraded repeats.
    • Intuitive on-board controls.  I much prefer knobs over buttons and menus; the six on this unit seem sufficient to expose a good degree of tweakability without getting over-complicated.
    Things I'm not so keen on:
    • Switching patches using the small on-board button is a bit fiddly.  I tend to only use one per song, but if I find myself needing to change more frequently, an external switch will be necessary.
    • No display.  That's a trade-off against the small footprint, but (related to the previous point) I sometimes wish there was at least a way of showing a memorable name for the current patch.
  • Ro_SRo_S Frets: 929
    edited May 2016
    I don't have a pedalboard as such, but here are photos of my pedals as at two years ago:
    fuzzy ones:
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
    4reaction image LOL 14reaction image Wow! 0reaction image Wisdom
  • TimmyOTimmyO Frets: 7556
    BumFace said:
    Sorry I should of made that about more clear. The amp is mono but the effects run in stereo. Hard to explain the difference until you here.
    Nice board. Sherpa, I've got a h9 running in stereo. A lot of the presets don't seem to work.. Is this right? Do I have to change something in settings?n
    the h9 detects the connected cables and then sends stereo in and out. I found it mostly works on delays.
    No you have to tell the H9 to run stereo @BumFace - in H9 control you can select between mono, stereo and pre/post routing. Just connecting both could be for stereo or pre/post so the H9 can't jut detect them plugged in and switch to stereo.
    Red ones are better.
  • LightB4soundLightB4sound Frets: 161
    Little update for me as I am now using the Atomic Amplifire exclusively for most gigs/functions as it sounds great and is dead easy to use and setup (and to be honest no one cares what I am using!). But I am loving this set up at the moment
    fuzzy ones:
    you need a fuzz pedal
  • LewLew Frets: 1657
    fuzzy ones:
    Can you talk us through the signal chain? Where do you like your buffer?
    Lew said:
    fuzzy ones:
    you found a friend @lew...someone else that doesn't have pedalboard...;)
    @cabicular...thats a hell of a collection...but talk to me about that Pignose Pedal..
    Not my collection mate
    oh yeah...sorry mate...
    @Ro_s...this questions for you...what do you think of that Pignose pedal?
    edited May 2016
    which one?  there's two pictured.
    The Pignose 'Detonator' is basically a Red LLama /  Craig Anderton Tube Fuzz Sound.
    edited May 2016
    :p
    A couple of bypass looper switcher boxes.
    Buffer near start of the pedal chain (but not before any fussy fuzz/germanium/etc pedals);
    buffer at the end of chain before amp; and
    buffer in amp's fx loop (if used).
    Tip for a cheap, very good buffer:  get any second-hand Visual Sound 'garagetone' series or 'V2' series pedal.
    didnt see the other one...which one is the detonator? and whats the other one?
    edited May 2016
    The one with two footswitches and two knobs is the 'Detonator SP'.
    The other, larger pedal is a 'Piggy in a box'  -  a Pignose 7-100 amp circuit in a pedal.  It is literally an amp in a box!   You can use it either as a dirt box, a preamp,  or an amp to a cabinet using the additional speaker out jack.   (Edit:  the pedal does not have an in-built speaker, although it may superficially look that way.)
    Both have very robust casings.
    I think both are discontinued.
    EDIT:  pic... image
    EDIT:  pic... image
    that's a pretty sweet pedal. I didnt even know they were making pedals!
    I'm thinking...Piggy in a box into a 100w slave amp...into a 4x12 would sound pretty nice
    Yep.
    I think the Pignose 7-100 amp itself has a speaker out capability, fyi.
    so finally got a cheap shelf, and put together my home pedalboard...it all sounds really nice and covers most my sounds too...
    @samzadgan - what's the larger pedal in the middle?
    @Ro_S thats a multiplex delay...really nice and can do some nice weirdness!
  • velvetsky01velvetsky01 Frets: 71
    Need some opinions....which configuration would people go with? As I am unsure - I think the top gives me more flexibility but interested to hear which one you would go for?
    Signal chain (top one)
    Wah - tuner - archer - (into QMX) ts mini - gunshot - Tim - TC flanger - lp trem - el cap
    Signal chain (bottom one)
    Wah - tuner - archer - (into QMX) Charlie Brown - Tim - TC flanger - lp trem - ep booster - el cap
    Here is my Trader Feedback Page - http://www.thefretboard.co.uk/discussion/62051/
  • slackerslacker Frets: 2254
    I've bought some pedals, retired some, swapped stuff around and this week I are mainly playing...
    Big board
    Small board
