Line 6 Helix
1187188190192193425
    edited October 2016
    https://dl.dropboxusercontent.com/u/630473/Last%20Chance%20Buried%283%29.mp3
    Warning: Ropey vocal ideas and ultra over-use of fuzz alert.
    John_A said:
    I can't figure it out, I'll ask over at the line 6 forum, but I'm sure you are right
    I'm sure I had a similar issue when using the pedal for volume
    Thinking about it you could reverse the action so that the toe down position was your minimum delay mix and the heel down was your max
    that way when you push forward and engage the switch you'll also set your delay to minimum
    all you have to deal with then is a lifetime of conditioning that pedal down means more :)
  • John_AJohn_A Frets: 3775
    ^ think this would be too much for my poor little brain, plus when I activate the Wah I do want a bit of delay
    Sure but you set the minimum mix to be 15% or something
    surely you don't have the expression pedal fading it to 0?
    I know what you mean though , I ended up just putting one of the wee line 6 expression Pedals on the board and using that for modifiers
    the only other thing you can do is assign the toe switch to a button and toggle the wah on and off that way
  • chrispy108chrispy108 Frets: 2336
    That bass tone! :grin:
    Cool innit?!
    What is it? All Helix is assume?
  • SporkySporky Frets: 28358
    That bass is awesome - from the lovely clangy attack I assume it's the Stingray?
    Yeah it's all Helix. With the Ownhammer Ampeg impulses, which are way better than the stock cabs.
    Yessir!
    So is this one:
    https://dl.dropboxusercontent.com/u/630473/GearDemo/Helix/Bass/Schism Bass Tone.wav
    Pitch whammy in front of a filter and a fuzz, then into the amp, with some delay and reverb. It sounds faiiiirrly close to the actual track.
  • rossyamaharossyamaha Frets: 2444
    I'm 99% there with this thing. Did 2 gigs this weekend, one in a large 3000 capacity theatre and one in a pokey little pub. It was killer on both. Figured out the switching so it wasn't that different to the way I use the Gigrig.
    4 cable method to the Lonestar, 1 preset with 4 snapshots a few things on instant access. Split the signal before it returned to the amp to send a stereo feed using a cab simulation to the FOH with ping pong delay but using the simple delay for my amp. Last night was the clincher as I could go out front and hear my amp as well as the direct signal. The difference was zero. The FOH was exactly the same tone as from the amp. Couldn't believe it. Gonna do a couple more gigs with it before I make the leap but I'm loving it.
  • welshboyowelshboyo Frets: 1816
    @rossyamaha can you screenshot your preset?
    cant get my head around running 4cm and FOH in one preset!!
    @welshboyo no problem.
    Drew_TNBD said:
    Yessir!
    So is this one:
    I would be most grateful for the patch. That's epic.
    Sporky said:
    Drew_TNBD said:
    Yessir!
    So is this one:
    I'll see if I kept it. If not, I'll rebuild it and post.
    @welshboyo here you go.
    http://i.imgur.com/D6GUOae.jpg
    Ignoring all the other blocks in the chain, the key bit is where you see the first effects loop block. Thats the 4cm method bit. You'll see next in line is a volume pedal. Then it's split into 2 paths. One adds a delay for my amp and output set to jack out. The other path has the cab simulation (Silver Bell), the delay and an eq just for volume boost which I match with the Lonestar and goes out through the XLR's in stereo. Works a treat.
    Ah, yes OK got it, so essentially your Lonestar preamp is feeding the IR?
    Exactly.
    So this was a weird little goal I had... get a Riverside-style chorusy bass tone, and a Tool 10,000 Days style lead tone, in the same song: https://dl.dropboxusercontent.com/u/630473/RiverTool.mp3
    Riffs are a bit generic, but just tone chasing really.
  • FarleyUKFarleyUK Frets: 2411
    Just got my Helix fixed and returned...... after about a week!
    Great work, Line 6 :)
    That is a quick turn-around! Good stuff.
