I still love my 10C - I have 5 different sounds on the 5 presets and often fiddle about finding others . I should save more of those to the software.
On the 10C the Trem and Delay effects are brilliant, easily a match for any good analogue pedal
This was the site. Each model of THR has its own section (the firmware is different so 10C patches not interchangeable with 10)
I picked up a THR10ii this week, the form factor’s great, BUT…
- the crunchy and hi-gain sounds are pretty shite out-of-the-box*, it’s taking a lot of dialling in and fiddling on the amp with diff. cabs etc. to get anything usable - it’s very fizzy!
- the app’s a bit clunky, but otherwise seems to do the job. It's bloody slow to 'scroll' through presets to demo them as a starting point!
- audio playback over bluetooth is decent, and having the audio and guitar level controls to-hand is brilliantly useful.
- the 'classic clean' model is lush, more dynamic than it suggests too.
My main aim is to get five usable tones dialled into the presets, then leave it at that basically! I only really use a few tones anyway, barring pedals, so that should be achievable once I learn the various amp models etc.
I must say though, based on initial impressions, had I tried one of the THRs in a shop prior to purchase I would not have bought it. The Vox Adio had far better gain-ier sounds in person.
* I’m tempted tot try a factory reset tomorrow, as I’m not convinced this one’s setup ‘correctly’. It needs a firmware update anyway, apparently.
Query to other THRv2 users - what are your go-to settings/patches?
The Good news, I found some decent hi-gain tones! Namely:
- General hard rock/metal tone: Classic (red), Hi-Gain (Dual-Recto), Gain ~5, Master 9, T~8, M5, B5
- Heavier/OTT gain: Boutique (blue), Special (Krank Rev.?), Gain 4.5, Master 10, T7, M3.5, B4
- With the above two, and minor adjustments on the Gain knob, I've been able to cover 99% of the rock and metal stuff that I play. It sits well in a mix when streaming audio through the THR too, which is a bloody handy feature that I've never had the option of before
The Bad news:- I'm not enjoying having to delve into the app to alternate between Classic/Modern/Boutique banks of models, the THR30ii model would avoid this.
- Similarly, the app is crucial for any editing of the effects, noise gate, compressor etc. I knew this prior to buying, but figured I could set-and-forget like I usually do with multi-fx units and similar!
All in all, I'm not convinced it's the amp for my needs. There's some good cleaner tones in there that are easy to reach, and the format really is excellent. I particularly like having the separate (and analog!) levels for Guitar and Audio outs to hand for practice with backing tracks/music etc. That said, I've got the luxury of choice here so I'm going to move this one along and revert to something a little more traditional as I'm stubborn and set in my waysjust because you do, doesn't mean you should.
I think the v2 amps merge the models from the three THR v1 variants, albeit with some tweaking perhaps. The THR10X was on my list, but I (rightly so) liked the look of the bluetooth audio streaming, and there didn't seem to be much of a cost benefit in going for the older model.
you bloody Cornickles, dont bleddy speak proper
