Line 6 Helix
1209210212214215426
  • MtBMtB Frets: 922
    There is an "Organ" patch which our lead guitarist uses - fantastic for renditions of "I do like to be beside the seaside". Oh, and it's not bad for the backing organ / synth on Oye Como Va. Works better with 'buckers than single coils.
  • TimmyOTimmyO Frets: 7446
    Do you know if he's put it on customtone?
    Red ones are better.
  • MtBMtB Frets: 922
    It came from the Helix custom tone library
    edited April 2017
    cheers
    Just saw this one - think the patch is available on the FB group
    TimmyO said:
    cheers
    ...and the patch https://line6.com/customtone/tone/2966595/ ;
  • MtBMtB Frets: 922
    Thanks for posting the link @TimmyO - I'll try the patch tonight
    Short vid on setting up some footswitches to control Logic Pro X record/stop/play via Midi
    AWESOME
  • keirkeir Frets: 137
    AWESOME
    I second this notion!
    Good deals with: handsomerick, majorscale, gassage, sticker, smudge_lad, anglian, edinfield99, thewiddler, thomfripp, notonlybutalso, JDE, chebellanga
  • stickyfiddlestickyfiddle Frets: 27108
    I have now played through mine for approximately 60 minutes and concluded I need to learn loads about how it works!
    Sounds are great though, and basic interface is great. I just have to work out how to do parallel paths, and how all this mode/patch/snapshot type stuff works.
    edited April 2017
    or if doing it in the editor :
    (I have no idea why all this guy's videos have reverb on his voice)
    Cheers! Will have a watch :dizzy:
    Facebook suggests there is another forum convert to our cult as of this afternoon...
  • fretmeisterfretmeister Frets: 24376
    He'll have to change his name now.
    Writing a lot of stuff right now that requires expression pedal control of a bunch of drives and delays at the same time to create textural stuff. It's pretty awesome for writing... only way I'm going to be able to pull it off live is with the Helix though!!
    That's my main advantage
    I use the expression pedals all the time
    When I use my trad pedal board a simple button boost isn't cutting it
    Weird...
    Have you lot got a "Stupor" drive pedal? The SD1 model?
    its not showing on mine but it's in the release notes.
    any ideas?
    Weird...
    any ideas?
    I have it, yes. Have you updated the Helix Editor as well as the firmware of the unit itself?
    yes!
