Barre chord thumb position
  • JalapenoJalapeno Frets: 6393
    ICBM said:
    Jalapeno said:
    On the topic of barre chords - they suck for anything other than solo/singalong performers - especially amplified, they fill out the mids in a really unattractive way. I'm trying to coach my other guitarist, if he can't be bothered to learn non-barre fingerings, then to only play the top 4 strings to avoid the dreadful din they make.  Compounded if you add distortion IMHO - yuck !
    You'd hate my playing then :) … I use a lot of full six-string barre chords, often with moderate distortion. It gives a huge sound in a one-guitar band.
    Not at all, I'm saying in a two guitar band it sounds fecking awful. Nowt wrong with Pete Townsend's sound in The Who !
    As for the thumb - nothing wrong with a wrap around (oo-er missus), it's the thumb position when barre-ing that needs to be middle of the neck, and up&down the neck to avoid injury - failing to barre properly gave me arthritis. Just played a 2.5 hr jazz gig without pain using 3 or 4 finger inversions and wrap-around barres (for min7 root on 6th string), with no pain at all !
    Feedback
  • RolandRoland Frets: 8723
    Evo said:
    Another nice Dmaj7 voicing...
    XX4635
    The question is where you put your thumb. On that shape I'd have it well behind because of the stretch.
  • underdogunderdog Frets: 8334
    I can't play with my thumb over the top, even when intentionally trying (learning some Hendrix licks) it's just feels alien and cumbersome to me.
  • ICBMICBM Frets: 72425
    One reason for this is that Hendrix had enormous hands. Mine are tiny by comparison - a little over half the span he had, going by what I've read - and I simply can't fret the low E string with my thumb and play anything more than a couple of frets further up on the first three strings even if I wanted to.
  • EricTheWearyEricTheWeary Frets: 16297
    Had to get a guitar out... astonished
    I rarely use full six string barre chords and find them uncomfortable after quite a short while. If I do then it's definitely thumb behind although I suspect it creeps up a bit high around the back of the neck. I do a few Steve Jones style middle four string barre majors and they are thumb behind as well, although as far as possible I play everything else thumb over and keep the thumb behind for special occasions. I don't have Hendrix/ Paul Gilbert style big hands though so the thumb is pretty much just for the low E.
    Although, let's be clear, playing guitar how I do it is no recommendation...
  • TheBlueWolfTheBlueWolf Frets: 1536
    Behind the neck for barre chords; I tend to adjust my fretting hand to get it comfortable. For widdly stuff my thumb ends up over the top.
    Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
  • thomasross20thomasross20 Frets: 4437
    Good to get some reassurance. Stupid YouTube video!
  • thomasw88thomasw88 Frets: 2328
    a few years ago I was getting some agonising pain in my wrists when playing.  went to a physio who said it was probably how I I was playing my guitar.
    So I  went to a teacher for a few lessons. he looked at my technique and thoroughly recommended playing with the Thumb at back of the neck in the centre.
  • darthed1981darthed1981 Frets: 11793
    Over the neck or at the back in the middle?
    Both - I can play most things with my thumb at the top but need to work on my finger at the back of the neck for chords like the 4-fret one in the middle of the arpeggio on the manics Design For Life, for example.
  • sekerisekeri Frets: 2
    I think you can find many resources here related to the topic https://www.myguitarworkshop.com/search/results/all/1/8?search_string=barre
  • PolarityManPolarityMan Frets: 7293
    The over the neck guys are you fretting the E and A strings with you thumb? Even that fees super cramped to me but i dont even understand how you would bar with your first finger across the whole neck and put your thumb over
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    edited June 2017
    When playing thumb-over I cover E, or both E and A, with my thumb. My index finger does a partial barre of the top three strings with my first finger. E and A can be fretted or muted. Using my thumb means that I can have independent muting of upper and lower strings, which is much more difficult to achieve with the index finger. On the other hand a full barre make it easier to mute all six strings evenly, especially when hitting muted strings as part of a strumming pattern.
    As I get older I tend to use full barre and thumb-over interchangeably to give my fingers a rest.
  • mburekengemburekenge Frets: 1059
    I learned the classical way, so I'm happiest that way.
    That being said, despite having midget 'chode'  fingers, I've been able to learn to fret the lowest e string with my thumb. Took a lot of work though.
