The last piece of the puzzle
WezVWezV Frets: 16692
edited November 2017 in Guitar
I have an old abused John birch i have been rebuilding for quite a few years now.   It had lost its original pickups but thanks to @philking i was able to remedy that... but i have never been able to find a set of  pickup rings
I have just had some 3D printed, which is my first attempt at anything like that, so I was quite relieved when the pickups actually fit
corner radius wasn't quite right, but i can live with that
here are some pics from the last decade... significant damage and razor sharp lacquer cracks
a black refin, the cracks went together well but were never clean enough to keep a burst
and some rings cut from scratchplate material - too thin but did okay for a while
  • WezVWezV Frets: 16692
    didn;t realise when i ordered something in black plastic it would be white inside with only a black outer layer.
    Anyway, i have shaped the bottoms to fit the carve (didn't fancy trying to 3D model that) and i have added the countersinks for the mounting screws, which i would have 3D modelled if i knew  they would be white inside.   Bit its all good, they need some  kind of finishing anyway, so i will probably spray black instead of clear
    its all good, they fit nicely.
    I was tempted to go with white, like this one
  • The shop I got my first electric guitar from (Neild & Hardy in Stockport - sadly it burned down) used to stock John Birch - that guitar has really brought back some memories.
    As ever, awesome work!
  • TTonyTTony Frets: 27582
    So, just let me check.
    You built a brand new guitar.  And relic'd it.
    You found an old relic.  And made it look brand new.
    :D
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • blobbblobb Frets: 2955
    Who takes the pickups out of a JB?
    Really nice resto, have you sussed the wiring out? Although saying that, they were all different and made no logical sense so whatever you do it will be authentic.
    Love to see a vid of it in action when you get it finished. Had a JB1 on my bucket list for a long time.
    Feelin' Reelin' & Squeelin'
    :D
    That about sums it up
    The pickups were swapped for dimarzios and actually sounded really great in this.  I assume it was all done when quite new as the dimarzios were early square footed ones and showed similar wear to the guitar.   otherwise i would just assume it was pillaged for some magnums, which fetch more money out of the guitars than in
    i took plenty of notes on the wiring, but was then told it was not standard by John Carling (iirc).
    I am not bothered about the stereo stuff and have decided to upgrade to new parts.   It will be standard LP with the master volume.   the mini switch will give out of phase.   I will probably put a varitone in the spare hole
  • SporkySporky Frets: 28350
    How's the 3D printed stuff? I've been concerned about the robustness.
    its a lot stronger than a normal pickup ring and the black outer layer seems to be very hardwearing.
    reshaping the bottom was interesting.  it sanded fairly well on the drum sander if you keep moving... if it gets too hot it will melt quite suddenly, but very localised.  i guess that is what you want from a 3D print medium
    i wasn't sure what to expect... but at less than a tenner per ring it was worth a go, even if it just got me close enough to make a mold and cast some
    That sounds worthy of further investigation.
  • I usually hate LPs, especially sunburst ones (too boring nicotiney-browny dadrock looking) but that's a supercool one to begin with (Birch's magic touches raise it to lushness) and you've actually made it even cooler with the refinish and details.
    pickups too yellow-aged for me (i'm brutally fickle) but otherwise it's one of the coolest LPs i've seen this year. i'm giving you an A. well done.
    https://i.ebayimg.com/images/g/uPIAAOSw0QFXB7g4/s-l300.jpg
    i am the hired assassin... the specialist. i introduce myself to you... i'm a sadist.
    so far so good.   I have given the rings a couple of coats of lacquer and buffed them out.  If i was after perfection i would coat in a finishing epoxy first, but I would rather not have them looking too perfect
    neck pickup needs a bit of adjustment to sit better
    I could look at that all day long. . . . . . . .
  • PhilKingPhilKing Frets: 1481
    The pickups and wiring loom were in a John Birch Flying V that didn't make it through hurricane Sandy.  The glue all separated and the guitar was in a right state.  I had 15 other guitars that did manage to survive, including an original Thunderbird 4 and Firebird 3.  My 60's 335 got water stains where it had been drilled to mount a stop tailpiece, but they were all OK otherwise.
    The Flying V never felt right (it was very neck heavy and didn't have much spacing between the pickups, all due to JB wanting to put 24 frets off of the body), so it was either build a new body or scrap it.  I decided to scrap it and put the JB bridge on my Wez JB SG and let Wez have the pickups and wiring loom (amazingly it was all working).
    found a couple of pics of it.  It really was a silly design
    what you can't see it hose pics is the large hand chiselled swimming pool route for the pickups, or the separation of badly warped fretboard post flood.
    I imagine it was from the same period as this SG
    They did later make a small number of V's with a more usable layout
  • Paul_CPaul_C Frets: 7788
    Not enough knobs !
