flattery will get you everywhere, Paul )
Bits I'm delighted with:
- It has absolutely the balance and gravitas I hoped for
- It is FANTASTIC to play (and not set up yet!)
- It sounds brilliant (and not set up yet!!)
Bits to tweak or think about:- The tone and balance knobs are deliberately separate from the volume. However, when I spaced them, I forgot about the fugly stacked pot knobs SD supply with their EQ so they visually look a bit closer together than I had in my head (I trialled it with 3 standard knobs before I drilled the holes). They are fine in use though
- I spotted a tiny bit of filling I've missed at the tailstock
- I've got to add the strap locks
Overall, I'm happier than a pig in s**t - can't believe how well this has come out...)
