Finished! Bubinga Fretless Bass Build
13»
    Thanks, folks
    I've got the ebony headstock plate on now and my moniker MoP Swifts.  I have to slim the width top of the neck down a little, but it gives an idea of how it's going to look:
    Still quite a lot to do but I'm on the home straight now (at last!)
    Andy
  • paulnb57paulnb57 Frets: 3087
    paulnb57 said:
    That, is a thing of awesomness.....
    As before!
    paulnb57 said:
    As before!
    flattery will get you everywhere, Paul :))
  • OK - just done the first sealing coat before getting down to the finish-sanding. I reckon end of next week should see this finished and playable:
    I may have mentioned the awesomeness of this before?........
    Anyroadup, when it's finished, pop it in the post to mine please, the Postie will know who it's for cos I'm Green.......with envy!
    Have a (another...yawn) wow!
    Thanks, Paul
    Andy
    Oh, my goodness!
  • I'll do the arty farty shots tomorrow (when hopefully the light will be better!), but it's basically finished.
    Bits I'm delighted with:
    • It has absolutely the balance and gravitas I hoped for
    • It is FANTASTIC to play (and not set up yet!)
    • It sounds brilliant (and not set up yet!!)
    Bits to tweak or think about:
    • The tone and balance knobs are deliberately separate from the volume. However, when I spaced them, I forgot about the fugly stacked pot knobs SD supply with their EQ so they visually look a bit closer together than I had in my head (I trialled it with 3 standard knobs before I drilled the holes). They are fine in use though :)
    • I spotted a tiny bit of filling I've missed at the tailstock
    • I've got to add the strap locks
    Overall, I'm happier than a pig in s**t - can't believe how well this has come out...
  • RolandRoland Frets: 8794
    It looks beautiful, and like any good fret less it looks very tactile
  • martmart Frets: 5205
    Looking very good indeed! Lovely work - you must be a happy man! :)
  • BigMonkaBigMonka Frets: 1784
    "Stunning" doesn't even begin to cover it!
  • Thanks folks.
    Yes - well chuffed.  Not perfect, but a step up from the 'prototype' :)>-
    Just think, only another 150 or so builds and I might.... as well whistle :))
    Oh, Andy!
    I think I've come a bit!
    Fantastic effort, I'd give another Wow, but well yaknow?
    Oh bollocks have another Wow!
     Shame about the pots, but well, WOW! A supreme effort!
    Now make and gift me one...with frettage!......
    Well done dude, give yourself a pat on the back etc, I wish I had half your skills.....
  • paulnb57 said:
    Oh, Andy!
    Oooo - er, missus  :))
    Thanks, folks - your encouraging feedback means a lot :)
    I found a better stacked pot knob-ring in my box of bits which, with a bit of drilling out, fits nicely.
    Here's one or two arty farty shots:
    Thanks once more -  you're all sweeties :)
    Andy
    Andyjr1515 said:Here's one or two arty farty shots
    You build very good instruments for a man who can't count
