Anyone still using a Boss TU-2?
noisepolluternoisepolluter Frets: 798
I know it's absolutely prehistoric and there are even budget clip-on tuners that are more accurate, but it just seems to keep doing a perfectly satisfactory job, and shows every sign of lasting a further 10 years at least.
  • gubblegubble Frets: 1746
    Sure am. It works fine in my opinion, is built like a tank and matches all the other boss pedals on my board. I see no reason for me to change/upgrade it
  • ICBMICBM Frets: 72404
    Yes, although currently only on bass.
  • EricTheWearyEricTheWeary Frets: 16297
    Yes, not sure why I'd change unless it broke/stolen.
  • GavRichListGavRichList Frets: 7164
    Mine does finally seem to be developing the odd quirk here and there. Ever so once in a while it just decides to go a bit mental.
  • richhrichh Frets: 451
    Me too, no complaints, still works well!
  • Yes, not sure why I'd change unless it broke/stolen.
    This. It may not be 100% accurate, but it's closer than Hendrix got...
  • professorbenprofessorben Frets: 5105
    Mines 12 years old and counting.
    Yes mine is 15 years old & needs a few minutes to settle down after switching on.
    Certainly close enough for anything I do!
  • jacksparrowjacksparrow Frets: 673
    mines going strong after 12 years cannot complain abou that.
  • SlimbertSlimbert Frets: 337
    I have one on my smaller board and it's working like new. It'll be on there until it dies in 2054.
    Is the TC Polytune the standard these days? I don't even know, such has my TU2 lasted. My concern about getting any non-Boss is that I'd lose my buffer at the beginning of my (very very lengthy) pedal chain.
  • english_bobenglish_bob Frets: 5156
    It's accurate, reliable (so far) and not stupid expensive, plus it does the polyphonic thing, so as far as I'm concerned it might as well be.
    It's what I bought when I needed a pedal tuner (actually, I should have bought one years before, and if I had it would have been a TU-2), and so far I haven't been disappointed.
    FWIW, you can build a simple buffer and a box to put it in for under a tenner.
    Doesn't matter if it's not as accurate then ;)
    I wouldn't know, I just use it for muting the bass between sets :).
    Same as me then ;)
  • TitchTitch Frets: 45
    Mine's been on my pedalboard for 15 years without any problems.
  • shaunmshaunm Frets: 1598
    Still use one, tried a polytune it wasn't as good as it sucked a bit of tone. I can't see a good reason to spend more money on something that does a job nearly as well as what I've got.
  • bbill335bbill335 Frets: 1378
    edited April 2017
    I've got two! Although I'm thinking of getting something with true bypass now I'm using 60s style germanium effects.
