Your Signal Path
DesVegasDesVegas Frets: 4604
edited April 2017 in FX
For this thread i am not concerned with the make and model of the pedal, just the order of your pedals in your signal path and what they do (i'm sure lots will just say Helix, and that is fine)
For example, mine is
Wah
Boost
Fuzz
Compressor
Distortion
Tremolo
Self Oscillating Flanger
Delay
Tuner - used mainly as a cut off for the above
EQ
Looper - reverb then flange then octave down
And lastly Delay
  • GavRichListGavRichList Frets: 7200
    edited April 2017
    You'll have it in the bloody format I have it and be grateful
    Boss TU-2
    Fairfield Circuitry Accountant
    MXR Micro Amp
    Crowther Audio Hotcake
    Fairfield Circuitry Unpleasant Surprise
    Fairfield Circuitry Randy's Revenge
    Electro Harmonix Pitchfork
    Mr. Black Thunderclaw
    Boss PS-3
    Mr. Black Eterna
    Electro Harmonix Freeze
    MWFX Mini Judder
    Digitech Whammy V
    Zvex Instant Lo Fi Junky
    Boss CE-2
    Boss NS-2
    Line 6 Echo Park
    Eventide H9
    Moog MF-104M (+ Dunlop DVP3)
    Eventide Space
    Mr. Black Supermoon
    Pigtronix Infinity Looper (+ Remote switch)
    *close thread*
  • DesVegasDesVegas Frets: 4604
    No Gav, exactly no ..
    fussy bugger.
    Ok
    tuner
    comp
    boost
    drive
    fuzz
    ring mod / trem
    pitch
    distortion
    pitch
    shimmer
    freeze
    glitch
    pitch
    lo-fi warble
    chorus
    noise surpressor
    delay
    multi
    delay
    verb
    verb
    loop
    Whoo Hoo!! Love it
  • SporkySporky Frets: 28672
    Helix, but for general use:
    Guitar
    Wah
    Compressor
    side chain with Octave down, dirt, EQ and compression for bassish sounds
    Phaser
    Dirt
    Phaser
    Delay
    Reverb
    Amp sim
    Tremolo x2
    Looper
    More reverb
    Putting delay and reverb before the amp was at Drew's suggestion - I rather like it.
  • english_bobenglish_bob Frets: 5164
    Alright:
    tuner (and signal turner-offer)
    compressor
    octaver
    (M5- various modulations, pitch shifters)
    overdrive
    overdrive
    delay
    (M5- reverbs, modulations, rotary speaker)
    booster
    M5 is in one loop of a signal routing flippy floppy box, the ODs and delay (and my amp's preamp section) are in the other, so I can use the M5 either in front of the amp/drives or in the loop depending on what I'm using it for.
    @english_bob ;
    do you use your octaver for octave up or down or both?
    DesVegas said:
    @english_bob ;
    It's a BYOC clone of the Mu-Tron Octave Divider- it can do octave down or octave down+octave up (but not octave up alone). It's analogue, so the octave up is in the Octavia/Green Ringer ballpark, so is more prominent around the 9th-12th frets, and both octaves get all tired and emotional if you play chords and/or play sloppy. I've normally got it set to give me both octaves.
  • BeexterBeexter Frets: 616
    edited April 2017
    With amp and pedalboard it's
    Guitar
    Wireless
    Fuzz
    Wah/Volume
    Drive
    Compressor
    Boost
    Tremolo
    Modulation
    Delay
    Reverb
    Amp ( no loop, no built in reverb)
    I also have a "satellite" board which I add for more ambient stuff which is an Ehx Superego with a Pitch Fork and Zoom MS70CDR in it's loop. I just plug it in between the reverb pedal and amp.
    Otherwise, it's
    Guitar
    Wireless
    AX8
    PA
  • TeetonetalTeetonetal Frets: 7815
    Helix for fun. This is completely and utterly movable, so not worth writing down..
    Live rig
    Front end
    Wah
    Tuner
    Fuzz / Flanger depending on gig
    Phser
    Chorus
    Drive
    Fx loop
    Dual Delay
    Reverb
    Tremolo
    Strat (important!)
    Tuner
    O/D
    Distortion
    Chorus
    Delay
    Reverb
    Fender amp (also important!)
  • Chorus/vib/flanger
    Pitch Shifter
    Klone
    Fuzz
    Main Overdrive
    Comp
    Delay
    EQ (used as solo boost)
    Volume pedal (tuner out to pedal)
    Reverb
    Rather unorthadox now I think of it, but it works very well for me.
    https://www.gbmusic.co.uk/
    PA Hire and Event Management
  • steamabacussteamabacus Frets: 1268
    edited April 2017
    My home rig is in a state of gradual evolution from this a few years ago and is currently ...
    compressor
    noise suppressor (send)
    (side chain to tuner)
    phaser
    clean boost
    overdrive/boost
    dual overdrive/boost
    pre-amp/overdrive
    noise suppressor (return)
    pitch shifter
    volume pedal
    rhythm/solo switchable attenuation
    (amplifier input)
    (amplifier fx send)
    analogue delay
    digital delay
    digital delay modeller/looper
    stereo digital delay (L R out)
    stereo looper (L R)
    Pre-amp/speaker emulator (x2 L R)
    stereo rack compressor (L R)
    (mixing desk L R)
    Stereo reverb (in desk aux send)
    .... I think?
    [edit] For comparison, my live rig ...
    compressor
    clean boost
    overdrive
    volume pedal
    digital delay
  • stratman3142stratman3142 Frets: 2204
    edited April 2017
    For my live rig I think this is the sequence, but I use a GT6 (in manual mode) with two drive pedals in the loop, so some of the internals to the GT6 are a bit of a guess. But this is how I'd basically arrange things for any set up.
    Guitar
    Tuner
    Noise Gate
    Wah
    Compressor
    Overdrive (Tubescreamer type pedal) - in the GT6 loop
    Distortion (more drive/distortion) - in the GT6 loop
    Volume pedal
    Delay (~300ms) with repeats
    Delay (slap back) single repeat
    Chorus
    3dB clean boost for a slight lift
    6dB clean boost to go from rhythm to lead
    Reverb
    Amp (into the clean channel) - nothing in the amp loop. The levels are set so the clean boosts don't overdrive the amp itself.
    The GT6 might soon be replaced with a Helix LT where I'd probably set things up in a similar manner
    For home recording it's:
    Guitar
    Zoom UAC-2 interface (USB3.0)
    Computer
    Reaper
    Ampsim (usually S-Gear 2 or Amplitube Fender 2).
    Yamaha HS7 monitors attached to my Zoom UAC-2
    It's not a competition.
  • BucketBucket Frets: 7751
    Guitar
    Wah
    Tuner
    Compressor
    Higher gain OD
    Lower gain OD
    Fuzz
    Chorus
    Delay
    Amp (front end)
  • lasermonkeylasermonkey Frets: 1940
    Tuner
    Fuzz
    Distortion
    Overdrive
    Boost
    Compressor
    Volume
    Phaser
    Flanger
    Chorus (stereo effects from this point onwards)
    Delay 1
    Delay 2
    Reverb 1
    Reverb 2
    into two amplifiers.
    My wife asked me to stop singing Wonderwall.
    I said maybe.....
  • vasselmeyervasselmeyer Frets: 3674
    Guitar
    Wireless
    Wah
    Feedbacker
    1) Compressor
    2)  Pitch shifter/harmoniser
    3) Light OD
    4) OD
    5) Fuzz
    6) Booster
    V) FX LOOP
    7) Mods (via  Mobius)
    8) Delays (via Nemesis)
    Amp reverb
    The numbered loops are all in a BOSS ES-8 so can  go in any order I want, although generally I keep them in that sequence. I also have an expression pedal which can talk to the pitch shifter  through a TRS cable via  the ES-8 and to the bods and delays via midi. Plus there's a tuner which isn't in the signal chain but is split out via the ES-8. The V is  movable so I can put any pedal in any order either before  or after the loop.
  • digitalscreamdigitalscream Frets: 26742
    Much simpler than most...
    Tuner
    OD
    Phaser
    Chorus
    Distortion
    Preamp
    Delay
    Power amp(s) (off-board, obviously)
    <space for hire>
  • Front of amp:
    Guitar
    Compressor
    Boost/Drive
    Effects loop:
    Trem/Vibe/Chorus/whatever the H9 is doing
    Delay
    Reverb
  • Brain
    Guitar
    Disappointment
    Additional volume
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
