Then really it is a matter of experimenting. Pick a drive pedal or 2, some modulation and see what the controls do.
If you have an FX loop then set it for the 4 cable method so you can have drive in front of your amp, and modulation / delays etc in the loop.
Guitar to Helix. Helix send to front of amp. Amp send to Helix return. Helix main out to amp return.
Then, say, put a drive pedal block, then a send / return block that your amp is in, then some delay.
hey
presto, drive is before your preamp, delay is in the loop.
Maybe check the global eq and impedance settings. There are some other guitar in settings too.
Mine does not colour my brunetti like this. I just checked.
Anyway, the input block has selectable input impedence. Set to 1Meg to match(ish) your amp.
If left on Auto it will model inut imped of the first block in the patch chain. Dunno what it defaults to if the patch is empty.
"You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
Eh????
Now, to start building some presets
Glad to hear it. I remember on release people thought it was colouring the sound a bit, but it was actually just set to the wrong impedance.
