Whats the beep sequence as in one long 3 short for example ?
Try a hard reset : Remove battery and charger - press and hold power button for 20 secs then release, plug in charger and then see what you got
Do you have an external monitor to plug in so that you can see if the display is knackered?
If the screen is faulty you can still tell if the machine is running by pressing the caps lock button on the keyboard and seeing of the caps lock light comes on ... if it doesn't then the machine hasn't posted
Do what I said earlier, you can also try reseating the ram but most likely if it's something like an Inspiron 5030 or similar is that the boards gone bad, normally the BGA joints under the GPU \ Bridge chipset
