Lap top help
HootsmonHootsmon Frets: 15996
dell inspiron  was beeping every second or so non stop and would not start now it has stopped beeping and looks quite.....dead
separate power supply looks OK and appears tae be working...any ideas?
tae be or not tae be
  • BRISTOL86BRISTOL86 Frets: 1920
    Sounds like a buggered battery to me.
  • dogloaddogload Frets: 1495
    My first thought was 'stuck key' but if it looks dead... have you tried switching it on without the battery? (worked for my Acer but the battery was absolutely knackered)
  • Danny1969Danny1969 Frets: 10471
    The beeps are error codes ... telling you stuff like can't find GPU or memory
    Whats the beep sequence as in one long 3 short for example ?
    It doesn't need a battery to run ... it can run happily off the charger
    Try a hard reset  : Remove battery and charger - press and hold power button for 20 secs then release, plug in charger and then see what you got
  • HootsmonHootsmon Frets: 15996
    if I recall the beeps were every few seconds without stop and no sequence....I think....
    Duh, I'm too used to living in Apple land!
  • scrumhalfscrumhalf Frets: 11364
    Can you hear any activity? Any souonds of disk thrashing that might indicate a hard disk failure?
    Do you have an external monitor to plug in so that you can see if the display is knackered?
    no activity.....it's an ex lap top
    It will attempt  to post with no harddrive fitted or a duff drive
    If the screen is faulty you can still tell if the machine is running by pressing the caps lock button on the keyboard and seeing of the caps lock light comes on ... if it doesn't then the machine hasn't posted
    Do what I said earlier, you can also try reseating the ram but most likely if it's something like an Inspiron 5030 or similar is that the  boards gone bad, normally the BGA joints under the GPU \ Bridge chipset
  • webrthomsonwebrthomson Frets: 1031
    On the up side most Dell kit you will be able to get the drive out of so if there is stuff on there you need you probably still have it!
