I can hear the effects if i switch it on, even if the guitar volume is turned down.
So i'll cycle through its pedal effects, and hear a phaser noise when its on phaser, flange, step etc.
Dunno what that is?
Kept my amp plugged into the extension, but powered just one pedal at a time via the same double mains wall outlet that the extension is also plugged into.
Each pedal has what I call noise floor. Ie it hisses when turned on, not playing. Admittedly gain was up and volume at piss downstairs off level. Both the boss and the marshall. The marshall has weird interference type hiss/static.
So I then tested each pedal on its own running off just a battery.
Same result.
Both pedals patched together both running off its own battery.
Same result.
I thus deduct I currently have no more noise than whats normal by using my normal setup of both pedals running off its own boss psa from the same mains extension.
Friday I'll see if adding a third pedal via its own psa to the same mains extension inteoduces any extra noise.
Im hoping not because after the 3rd pedal, the tuner arrives thats me sorted for a while for pedals and power!
I could mess about with daisy chaining but while i have no more than what must be normal pedal operating hiss, theres little for me to gain.
It would look neater but hardly as I've tucked all the cabling away nicely anyway, and this gear never gets moved to boot..
Hopefully I'm all good!
I have a TU-3 now but I haven't tried putting it first...I need to experiment!
I usually like the Boss tuners as a good line driver at the end of the board (or at the end of the bit in front of the amp, if the modulations are in the loop) to make sure the cable to the amp is properly buffered.
On my 3-pedal bass board I have the tuner after the fuzz and before the chorus, not least because it's hardest to hit by accident and mute the whole thing there .
