Ello guys. Im not hugely up to speed with effects etc.
I have a boss tu-3 on the way, and presume it will go first in my chain?
I currently have my guitar, into a boss oc-3 octave, into a marshall regenerator, into the front of a katana 50.
Also regarding power supply.
In hindsight it would have been cheaper to get an isolated brick, but you know...
Anyway, these 3 pedals will be all powered by their own boss psa adapters which are plugged into a 6 way mains extension. The katana 50 is also plugged into the same extension.
Is that kind of the same as having an isolated power supply?
I always get anxious about waiting for new things to turn up... lol.. always think theres gonna be some form of problem
Yes, using all separate BOSS power supplies is just the same as isolated.
"Isolated" is referring to the earth, so isolated power supplies don't share a common earth and that's how they can be used with a mixture of digital and analogue effects.
I don't *think* there's a problem with running all that off one plug bar extension lead but I'm not an expert.
@ICBM (other amazing techs are available) will know TONS more about why this is than I do but doing it the way you're doing won't harm anything and putting the TU-3 first will act as a mute when activated (Handy) and a buffer so that's a good idea too.
I've always put my TU-3 first in the chain when I used one.
People tend to have tuners at the start of the effects chain in order for it to see an unaffected signal although I think only modulations would really trouble the tuning. The other choice can be at the end so if you have pedal hiss the tuner will cut that all off. It also acts as a fault finder at the end of the chain - if you lose signal but the tuner can still read your guitar then the problem isn't on your board ( and vice versa). However, as you only have two other pedals I suspect those are none issues for you.
As for power supply personally I would use an isolated brick e.g The T-Rex, or use the TU-3 to daisy chain the power to your other pedals.
None of this ever needs to be taken out of the house so its no real problemo not having everything compact and easy to remove..
Figured I needed a tuner and the boss one gets a popular press.. I've been using an old line 6 amp with built in tuner as my tuner haha.. but that means plugging it in, and generally getting off my ass.
Did have a freebie clip on tuner from andertons, but free for a reason.. it doesnt like some strings and can be a pain to get to pick up certain high notes.
The Polytune is also awesome, I have one of those too but its not velcro'd on my board, so if the board is in storage somewhere else I have access to another one.
As a buffer and a tuner they're amazing and I've always thought they're a bargain for what they cost.
If I didn't use the GT I'd insist on using one even if I was playing straight to the amp. The buffer is just brilliant especially when you're dealing with stage length cables.
To be able to use it to daisy chain power is just another reason why they're amazing.
up as a power supply which is awesome and not
too many people know or use this feature but super handy! They can power 4/5 other pedals if you have a daisy chain lead
Ed Conway & The Unlawful Men - Alt Prog Folk: The FaceBook and The SoundCloud
'Rope Or A Ladder', 'Don't Sing Love Songs', and 'Poke The Frog' albums available now - see FaceBook page for details
Why use 3 PSAs? Just use one and daisy-chain out of the tuner. Neater, less wasteful (heat from 3 transformers) and less potential problems. Carry one of the others as a spare.
"Isolated" is the new "true bypass" imho. You don't need an isolated 9V supply for every pedal.
Also first in chain is good, I use the zoom cdr70 as my tuner and it's last and recently I came a cropper when it just didn't want to work properly and I couldn't seem to tune to pitch.
It was because like a fool I had left my pitchfork on tuned to a different pitch.....doh.
Instagram is Rocknrollismyescape -
FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
I run my TU2 after my soul food and big muff but before my Boss Blues Driver.
Quite simply because I've five boss pedals and I like them all lined up in a row on the board - it looks all neat and tidy.
if i want to tune up i just turn the dirt pedals off
re:Clip ons - they rely on neck vibration - top tip if you're have trouble, play octave harmonics at 12th fret, works a treat
Feedback
You might get more noise daisy chaining, you might not. It wouldn't be too surprising if the Regenerator didn't play well. Daisy chains are pretty cheap so you could experiment if you wanted to.
