I like to use 2m lead for an amp. It saves on mains extension cables.
A true kettle lead has a notch in the plug, by the way… that's properly called a 'hot condition' plug, but will still work with the amp if you need it to, although they're usually short.
Don't let anyone tell you that the cable makes a difference to the sound . If it did, it would be an inadequate gauge and would be so thin that you'd spot it as not being up to the job straight away. No commercial IEC/kettle lead will be made from cable like that, it would fail safety regulations.
5A is high enough for most amps. Have a look on the back of the amp to see what input power it draws (in watts), then divide that number by 240 (volts) and that gives you the value of the fuse required (in amps)
http://www.ebay.co.uk/itm/UK-Mains-Power-Lead-Cable-For-Gear4Music-Gear-4-Music-Guitar-AMP-Amplifier-5M-/152234201646?hash=item2371dd922e:g:eekAAOSwFdtX0URd
http://www.ebay.co.uk/itm/2m-Long-IEC-Kettle-Lead-Power-Cable-3-Pin-UK-Plug-PC-Monitor-C13-Cord-/322430238351?epid=862609161&hash=item4b1256fe8f:g:JFcAAOSwtfhYq9lq
grab a pack of 5A fuses from the £ shop
They are correctly called BS1363-1 to IEC-60320 C13 cables.
http://cpc.farnell.com/schurter/4781-0100/iec-connector-hot-condition/dp/CN03854?mckv=soFlHHKtP_dm|pcrid|72935646737|kword||match||plid||pid|CN03854|&CMP=KNC-GUK-CPC-GEN-SHOPPING-SCHURTER-Connectors-CN03854
As you were gentlemen.
And a whole ruck of these cable ties, then you'll know which is your stuff. Sugges to the rest of the band that they use their own colours.
http://www.ebay.co.uk/itm/100PCS-Reusable-velcro-Cord-Adjustable-Cable-Tidy-Strap-Ties-Tidy-Wrap-Hook-Loop-/152632276123?hash=item238997b49b:g:0xcAAOSwfjhZccVn
http://www.monkeyfx.co.uk/pictures/FancyMainsCable.JPG
The cable itself is covered in rayon braiding, which has no effect whatsoever on electron flow. The plug is transparent, but has no effect on the transparency of the signal, and the amp end is white because that's more interesting.
You could be on to business venture here...
https://www.amazon.co.uk/Power-Extension-Cable-female-C13-C14/dp/B000KTQI4I/ref=sr_1_1?s=electronics&ie=UTF8&qid=1501763519&sr=1-1&keywords=iec+extension
Lifesaver on a few occasions - when wanting to position the pedalboard a decent distance from the amp.
