Tweed combo was my thought. An old one would probably cost a fortune would it not?
but what do I know ,perhaps this is what a lot of people like
One mans meat I guess
Beautiful cleans and lovely break up tones but you need to crank it to get the grind and it becomes far too loud in a normal band situation. I don't use pedals for dirt, I want it to come from the amp, so for me it was not suitable. Actually, a 20w version would be ideal. Anyone make anything like that?
I didn't find it heavy or awkward to move, I thought it was surprisingly light given the size....although I am used to a BadCat....and I'm of impeccable muscle tone and strength, not to mention exquisite good looks and modesty.
(formerly miserneil)
Yes, by varying degrees, but would use a pedal.
They're OK for a very trad country/blues type of sound, although not loud - you *might* be able to gig one on a modern 'quiet' stage, but unless it's a tiny room it will definitely need to be mic'ed as well. They sound nice at low volume though, so one would be a good choice for a guitarist who occasionally plays bass at home.
For what it's worth, the reason the speakers are each connected with their own separate RCA plug is because the originals blew one or two about every gig, so Fender intentionally made them as easy as possible to replace! They supplied the speakers with the cable and plug already soldered on.
In the end, my Pignose G40 (same circuit but with master) had that brown sound aplenty and made the Bassman redundant - I traded the 59 for a 57 Deluxe and now have best of both...
http://i57.tinypic.com/25tw8ds.jpg
At least Line 6 didn't model the speakers blowing every gig
They are totally different amps. Almost the only things they have in common are the name and the valve types. There's a fair difference between the Blonde and Blackface too, but they're much more similar than either are to the Tweed.
