Hello - apologises if this is in the wrong thread......
Had a panic at this weekends gig - was setting up at a festival, quick change over facilitated by the sound crew - anyway I couldn't get a sound out of my guitar. Worked out in the end half the pedalboard was down - the half supplied by my Fueltank Jnr. I had to size my pedal board down to one power source very quickly. Just goes to show I dont need half the sh*t on my board!! Anyway when I got home I took the board apart and put it back together and it works fine!!!
It got my thinking though and if something went wrong with my amp I really wouldn't know what to do so -
I am thinking of getting a DI box as a plan B
If I get one I am assuming I can still use my pedal board - but that it'll just sound different as it won't be interacting with my amp anymore?
Thanks all
A DI is essentially converts from unbalanced instrument level signal to balanced mic level.
That won't sound very good if you plug your guitar into your pedalboard and then into a DI unless you have some form of cabinet emulation.
I would look for a modelling device (probably a pedal) that outputs at line level and plug that into a mixer's line level input.
It is worth having a DI in your gig bag in case the mixer doesn't have line level inputs and only has mic inputs.
Don't go too cheap with a DI- I have a bunch of them here- the cheap Chinese crap Is more trouble than they are worth.
I have a couple of Groove Tubes ones that always worth great- otherwise look at Radial.
Right - thanks @octatonic that's really helpful. I don't have any sort of cabinet emulation. Our mixing desk does have line level inputs and if were not using our PA were normally at a good club or festival so that shouldn't be an issue.
So I am looking for a modelling device? What is it just a pedal that models an amps sound? Does it have any use other than as an amp back up?
Or you could have a cab emulation box like a Hughes & Kettner Red Box and plug that into the mixer.
Or something like a Sansamp pedal- there are a lot of solution out there but my point was that a DI by itself won't do it.
Right, brilliant - thank you @octatonic. I didn't know that - time to do some research.
What do you do out of interest?
When I gig as a guitar player I have a Sansamp pedal in my gig bag.
I've never had to use it though.
When I gig as a bassist I have a DI on my pedalboard (actually part of my Peterson tuner) to go to the mixer.
Cheers @octatonic - I've learnt some stuff there. Hopefully I'll never need it but I wouldn't want to let the side down on wedding gig or something.
Our drummers talking about getting his own mini mixer for his drum mics (probably so we can't turn him down!)
Luxury!
I just hit them harder.
Thank you - any recommendations?
Very helpful thanks @maltingsaudio @octatonic also mentioned the Sansamp. I'll do a bit of research. Cheers.
I haven't used that one but I imagine it is excellent.
https://www.amazon.co.uk/JOYO-JF-15-California-Sound-Effect/dp/B0086EQPWE
Not sure it's line level output so you might need a DI box as well - although most sound engineers should have DI boxes anyway. If you do want to get your own, you could get an Orchid Micro DI for under £30 last time I looked.
https://www.soundonsound.com/reviews/orchid-electronics-di-boxes
