(good point, but in EU. Med cruise!- neck is 1965 and is stamped tho.)
@gassage - make sure you put any screw driver etc in the case as well as they can't go on as hand luggage - I accidentally left my Leatherman in a rucksack this year after a walk a few days earlier - the second it was flagged under x-ray I knew what it was - by by Leatherman and I bet they don't bin it either
I'm not a fan of taking on/off to many times as one day the wholes will need to be re-plugged as otherwise they become to loose for the screws
Indian RW? Then you're fine in the EU.
Re neck bolting on off, it won't be off long enough to affect the TR I would have thought. Stick some strings in your hold luggage just in case.
I would probably tell the airline. I doubt airport security would give a toss.
Crikey. If I replied to all of them I'd never be off here
I turned a Brz sale on a PRS down the other day to Singapore as it was just likely to go wrong
https://www.facebook.com/bumblefoot/posts/10154852023653085
I'd have thought the obvious thing to do would be;
Travel - buy guitar - play guitar for a bit - sell guitar - travel home.
Not much different to normal, except for the travel bit.
@Gassage - are you in the ship's band?
