It can also be a way of supplying more current (or different voltages) for pedals that need it if the supply with a daisy chain isn’t big enough.
Some supplies look look like they have separate outputs but they aren’t so it’s worth double checking the are isolated as well as watching the available current.
Tate FX
www.TateFX.co.uk
Instagram
Everything on my board is entirely analogue apart from the tuner and as far as I can tell daisy chaining it all up does not add noise. My wireless squealed like a pig though so that's on a separate supply.
In general, there might be *some* improvement in tone from using a "proper" PSU designed for audio applications, particularly if you're upgrading from a cheap and cheerful generic adaptor, but some of that might also be placebo.
As long as you aren't hearing any unwanted buzz or hum (that doesn't go away when you turn the guitar volume down), whatever you're using now is probably fine. As and when your pedalboard draws more current than your PSU can comfortably provide, or if you need to isolate noisy pedals, or if you end up needing multiple voltages, then it's time to look at another PSU.
There's probably some wisdom in buying a really good PSU *before* you encounter those sorts of problems, particularly if you're a gigging musician, but given that it's likely to involve dropping £100 or more on something that isn't nearly as exciting as a new effects pedal you might not be in a rush...
Shame there's nothing else out there that does what the M5 does but doesn't cost way more money.
But I'm running about nine pedals, including a DD-20 (200 mah with a current doubler cable) with the Power Plant Jr, so it can be done, to a point.
Ive changed to a full GigRig set up with isolators etc and it’s even quieter despite having 10 pedals on the board (including an M5). F’ing expensive but much lighter and very quiet.
If it’s not bothering you, it’s not an issue but I’ve loved the improvement to my sound from not having humming, digital clock noise etc sitting in the background. Although how much of that can be heard in a band mix in a pub is a bit moot...
How good are the HB PowerPlants? Is it a false economy and I'm better just biting the bullet and getting a OneSpot CS7?
edit - here's a link, they seem sturdy and well spec'd
https://www.thomann.de/gb/harley_benton_powerplant.htm?ref=search_rslt_power+supply_119603_25
Is 100mA generally ok unless it's something big?
It says it's isolated, 9V, 12V and 18V. Appears to get good reviews etc and has 10 outputs.
http://stinkfoot.se/power-list is a really useful resource for working out what your power requirements are.
https://www.amazon.co.uk/Guitar-Pedal-Power-Supply-Overcurrent/dp/B06XPG8B71/ref=sr_1_4?s=musical-instruments&ie=UTF8&qid=1509615532&sr=1-4&keywords=guitar+power+supply
