Deciding where to split the signal would be part of the fun- you could use the preamp section of one amp, split the signal in the effects loop and send the signal to the effects return to two different amps, or you could split the signal earlier in the chain to use both the preamp and power amp sections of two different (or two identical) amps.
So I'm thinking splitting the signal somewhere to enable this wet/dry scenario. The TPS show mentioned above still doesn't explain it enough for me to where and how to spilt the signal. To further complicate things I do sometimes go out with one amp so using my Sum to Mon box is gonna come into play there
Most of the gigs we play I don't know where I'd even put an extra amp.
It's farly simple, if you keep if fairly simple. Use something like the GigRig Humdinger - place it after your drives and then use one output to continue the journey through modulation and delays / reverbs and onto amp 1, then use the other Humdinger output to go directly to amp 2. If you place the amps together on a small stage (and don't be tempted to spread them out too much), it should work a treat.
You can then use your output 1 above for when you use a single amp (and not run out 2 at all) but you will need to readjust your effects levels as you get away with a lot more of everything when you run wet/dry.
I would imagine 90% of provided FOH engineers will greet 'I'm running wet/dry" with a look of distain or fear. In smaller venues atleast :P
Majority I've come across don't wanna take a stereo signal from a modeller that literally involves panning one left and the other right and keeping the settings equal!
We're a bunch of negative party poopers here right :P
The short answer for most these cool wet/dry, wet/dry/wet, stereo, dual amp, multiple mics... they sound fucking awesome when they're set up right at home in the studio, or if you've got all day at a big venue to sound check with a sound engineer who knows what you want.
In a small venue, where you're set up and sound check is 10 minutes before you start, the promoter has shoved 6 bands into a 3 hour event, a sound engineer will get some levels then sit on their phone with ear plugs in through your set so they don't notice the backing mic isn't on ... it may be more hassle than its worth!
